need help, Horn Problems on 94 del sol
Hey, I was wondering why my Horn won't work. All the wires for the horn are in place. None of the fuses are blown, already checked. Any Ideas? Could it be the Horn buttons on the steering wheel?
btw, this is my first post although i joined this forum a month and a half ago.
get someone to hit the horn button while you check to see if there is power at the horn.. use a 12v test light. to see if it is getting power. then go from there
scarponze
scarponze
in the harness of the srs unit where the horn goes into, theres suppose to be a connecter thingy that bridges two of the pins within the harness. I forgot which pin thou just use speaker wire to bridge them if there is no connecter do a trial and error. maybe thats your problem for no horn.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngrain1 »</TD></TR><TR><TD CLASS="quote">I checked the plug to the horn and there is power at the horn, but its still not working. </TD></TR></TABLE>
Sounds like your horn itself is shot, get a new one. If theres power going to it and its not working its the horn.
HairyHarry
10
May 14, 2020 12:56 PM
DaAzNpLaYbOi
Oct 10, 2005 02:43 PM
