HELP!
HELP FIX THIS ITS MY CAR!
okay! i trade my eg hatch for a del sol and the horn does not function at all in other words it does not work...i check the fuse box and it look fine....any suggestion...
Modified by 93_cxEG at 1:11 PM 2/23/2005
or just run 2 wires from your horn to the battery to test it. If it works, maybe something is disconnected on the steering wheel side. For instance, is there a factory steering wheel on there ? Sometimes the horn is not connected on the aftermarket steering wheels on Del Sols, because it requires some re-wiring work.
Re: (DelSolSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSiR »</TD></TR><TR><TD CLASS="quote">or just run 2 wires from your horn to the battery to test it. If it works, maybe something is disconnected on the steering wheel side. For instance, is there a factory steering wheel on there ? Sometimes the horn is not connected on the aftermarket steering wheels on Del Sols, because it requires some re-wiring work. </TD></TR></TABLE>
be sure t run the wire from the battery to the horn, u want ur ear right next to it, when u try it because the 12 volts isint enough juice and make the horn real quiet, so get ur ear as close as u can to the horn!
Re: (johnzm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm »</TD></TR><TR><TD CLASS="quote">
be sure t run the wire from the battery to the horn, u want ur ear right next to it, when u try it because the 12 volts isint enough juice and make the horn real quiet, so get ur ear as close as u can to the horn!</TD></TR></TABLE>
oh okay i'll do that...WTF...who do you think i am...i know that **** is going to be loud u DF....man your ruin my thread get out....
Re: (93_cxEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG »</TD></TR><TR><TD CLASS="quote">
oh okay i'll do that...WTF...who do you think i am...i know that **** is going to be loud u DF....man your ruin my thread get out.... </TD></TR></TABLE>
I'm surprised you haven't been flamed, or docked because of the thread title....you're ruining the forums...get out or read the rules.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Rules »</TD></TR><TR><TD CLASS="quote">2.A. Please do not post misleading or unspecific thread titles. Please don’t post “Help Needed” or “Look at this problem.” Make your thread titles specific to the question you are asking</TD></TR></TABLE>
Re: HELP! (93_cxEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG »</TD></TR><TR><TD CLASS="quote">okay tried hooking it up to the battery and the horn works...so can it be any wire or the steering wheel...</TD></TR></TABLE>
It'd be the horn wire in the steering wheel... do you have SRS in your sol ?
Re: HELP! (93_cxEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG »</TD></TR><TR><TD CLASS="quote">yup i have sr5...hmm how would i connect the horn then...oh yeah my del sol year is a 95 model...its a S model...</TD></TR></TABLE>
is your SRS light on on your cluster ? reason why I ask is because there is a harness underneath the steering column, it has a yellow plug which connects both the SRS and horn.
Re: HELP! (93_cxEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG »</TD></TR><TR><TD CLASS="quote">yeah it does comes on...yeah...and is there a way where i can by pass that and make it work.</TD></TR></TABLE>
yes its on forever...
Re: HELP! (DelSolSiR)
CK these wires!
what do u mean by CK...and which wire should i check...
CK these wires!
Re: HELP! (93_cxEG)
what do u mean by CK...and which wire should i check...</TD></TR></TABLE>
CK, short for Check. These are the wires that you will see when you remove your SRS on the steering wheel to see the wiring for your horn.
