Bad rear wheel bearing replaced, Len / Baranco roxxors!
I had a rear wheel bearing go out, I don't know why. The other side is fine. Len hooked me up, as usual, and got the parts to me in time to get #1141 back in action without downtime! THANKS LEN, you 'da man!!
It started making noise which sounded like a blown out exhaust at first. Then it started to groan, and it was obvious what was failing. It was so easy to fix, it took about 15 minutes. Just a reminder to check your rear wheel play next time you rotate your tires.
Precision bearings that are simply replaced with the hub as a unit, and do not require solvent, regreasing, or spindle (trailing arm) replacement. $140.
ShinyNewPenny
13
May 28, 2009 06:30 PM
