tail light problem
my brake light on my passenger side went out. tried replacing bulb but still didn't work. i check the wire for voltage and got nothing. i was just wanting to know were the wire plugs in at. im trying to avoid ripping out my whole interior to trace it.
the wires are connected to the whole body harness that connects under the dash and the seats. i would suggest tracing the wire is your best bet. or simply cut the power wire and run another from the opposite side
it has power so it should be fine just make sure to cut and tape the original wire incase its shorted to ground or broken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autounderground »</TD></TR><TR><TD CLASS="quote">the wires are connected to the whole body harness that connects under the dash and the seats. i would suggest tracing the wire is your best bet. or simply cut the power wire and run another from the opposite side
it has power so it should be fine just make sure to cut and tape the original wire incase its shorted to ground or broken.</TD></TR></TABLE>
Well Said...
Well Said...
wtemale
Nov 18, 2017 05:08 PM
vthree
May 6, 2006 03:56 PM
