Complete Transmission Swap. Any Good Links? Guides?
Old Sep 12, 2004 | 02:49 PM
Traction's Avatar
Default Complete Transmission Swap. Any Good Links? Guides?
Apparently my throwout bearing took a **** on friday night. I already knew my clutch was slipping, so instead of overhauling my tranny that grinds in reverse, I opted to buy al already built tranny from someone local.
Has an act clutch and a fidanza 9lb tranny, new release bearing and everything.
Only $350
Im completely new really to doing any of my own work. So does anyone have a good guide for completely removing the tranny in your driveway without power tools or a jack lift
The part Im going to have no clue about is the axles
If anyone could provide me a link or even type something out with pics on axle help I would hugely be appreciative
Old Sep 12, 2004 | 03:54 PM
Traction's Avatar
Default Re: Complete Transmission Swap. Any Good Links? Guides? (Traction)
cmon, I know this forum isnt entirely filled with people worried about cosmetics
Need some help
Old Sep 12, 2004 | 04:27 PM
doublethink's Avatar
go to the main part of this forum.
look at the top.
see where it says FAQ Topics.
that might be a good place to look.
in the first post of that thread:
<U>Axle Replacment Thread, with or without power tools.</U>
https://honda-tech.com/zerothread?id=382416
<U>LS 5th gear install</U> (its for a b16a but you can get a lot of info from there.
https://honda-tech.com/zerothread?id=555929
im not trying to be a troll, but you dont look then you say i know some of you arent into cosmetics??
Old Sep 12, 2004 | 04:35 PM
senpai's Avatar
http://www.geocities.com/senpa....html
Old Sep 12, 2004 | 07:41 PM
Traction's Avatar
Default Re: Complete Transmission Swap. Any Good Links? Guides? (senpai)
Some descent pics right there
Old Sep 12, 2004 | 07:57 PM
SuperSteve737's Avatar
Just asking to rip his ball joints.
Old Sep 12, 2004 | 08:03 PM
autounderground's Avatar
ok, i am a honda builder in nyc and have done alot of trannys, i can do a motorand tranny swap in 3 hours. i would suggest a professional with the proper lift and equipment but if you must do it yourself then so be it heres how i do it.
1.disconnect and remove the battery. remove the cable from the shift fork, and the cable from the speedometer sensor.
2.place the car on jack stands and chock the wheels.
3.remove the wheels.
4.remove the bolt connecting the shock to the lower control arms, its a 17mm bolt and nut.
5.remove the center nut of the axle should be a 32 mm.
6.drain the transmission of fluid by removing the plug on the bottom its a 3'8'' ratchet plug.
7.using a screw driver a large screw driver pop the passanger side axle from the transmission. and the drivers side from the half shaft.
8. the half shaft is connected to the engine block by 3 14mm bolts.
9. the starter is connected on top by 2 14 mm bolts one is kinda trickey to get at and i normally only put one back in the instillation stage.
10. the transmission is connected to the engine by 4 or 5 17 mm bolts around the bell housing.
11. remove the bolts on the passenger side mount 3 bolts on the tranny and one going through the mount.
12.theres one mount on the fron side by the radiator. and another ""L"" shapped mount in the back by the half shaft. at this the tranny should be able to come out . just be careful they dont seem liek they weigh alot but on ur back with one on ur chest they can get to be a bitch.
i hope this helped you a little but if you have any more questions let me know email me at autounderground@aol.com
Old Sep 12, 2004 | 08:57 PM
Full Race A6's Avatar
Default Re: Complete Transmission Swap. Any Good Links? Guides? (autounderground)
Everyone seems to have a different way to tackle the axles
Anyone have the best easiest way to not **** **** up
Old Sep 12, 2004 | 09:04 PM
yellowcrx1991's Avatar
Default Re: Complete Transmission Swap. Any Good Links? Guides? (Full Race A6)
The only part of the transmission removal process that you can "**** up" would be the lower ball joint removal.
From what other posts have suggested, a generic ball joint remover tends to destroy the rubber boot on the lbj, others suggest visting a local Honda dealer and buying their ball joint remover, you could also attempt to use some leverage to pop it off, still others(like me) suggest using a BFH and banging it against the ball joint, it'll pop right off.
If your going to use a hammer, when you remove the castle nut on the lower ball joint, screw it back on about 2-4 twists with your hand, this will help to ensure that if you miss your target, you don't strip the threads.
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full Race A6 &raquo;</TD></TR><TR><TD CLASS="quote">Everyone seems to have a different way to tackle the axles
Anyone have the best easiest way to not **** **** up</TD></TR></TABLE>
remove the ball joint nut and smack the LCA near where it connects to the knuckle with a hammer. Take 2 or 3 good wacks and the ball joint should loosen up! THats how we do it at Honda
remove the lower shock fork bolt, remove the 32mm nut, slide the axle out of the hub, and then pry the axle out of the tranny with a pry bar
Old Sep 12, 2004 | 09:21 PM
Traction's Avatar
Default Re: Complete Transmission Swap. Any Good Links? Guides? (Emerika)
Hey guys I dont want to seem unappreciative or anything but this is my first car and my first time actually doing anything other than bolts ons or suspension
I honestly dont know what you mean here,
Like smack the lower ball joint out of the LCA and slide it out of the hub
Would you guys possibly modify some pictures that I take?
Ill climb under my car tomorrow and snap a few pics and you can see do what with what....
Id be really appreciative if I could shoot you guys a pm when I get the pics up
Old Sep 12, 2004 | 09:24 PM
Get a Helms, best sixty bucks you will ever spend on your car.
http://www.helminc.com/helm/homepage.asp?r=
Old Sep 13, 2004 | 07:58 AM
senpai's Avatar
Default Re: Complete Transmission Swap. Any Good Links? Guides? (SuperSteve737)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSteve737 &raquo;</TD></TR><TR><TD CLASS="quote">
Just asking to rip his ball joints. </TD></TR></TABLE>
You don't understand the pics too well, do you?
That's removing the lower shock bolt, check the sections first before you criticize.
Old Sep 13, 2004 | 08:52 AM
crx_88_si's Avatar
Default Re: Complete Transmission Swap. Any Good Links? Guides? (yellowcrx1991)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowcrx1991 &raquo;</TD></TR><TR><TD CLASS="quote">Get a Helms, best sixty bucks you will ever spend on your car.
http://www.helminc.com/helm/homepage.asp?r=</TD></TR></TABLE>
^^ you'll need trq specs, etc.. get it.
Old Sep 13, 2004 | 09:44 AM
Traction's Avatar
Default Re: Complete Transmission Swap. Any Good Links? Guides? (crx_88_si)
Ive got a Haynes but by do they ever suck
Also Helms doesnt ship without a credit card which I dont have
I didnt get a chance at those pictures this morning before work. Defientely tomorrow
kobeballer96
Nov 23, 2008 05:50 AM
jdm91CrxSi
Aug 17, 2008 07:22 AM
loclowd
Apr 30, 2006 06:42 PM
osiris316
Sep 8, 2003 05:26 PM
Soulless
Jan 29, 2003 07:49 AM
