Idle adjustment screw not working.
You have to unplug IAC before making the adjustements, because it will compensate the airflow.
Honda recommends to set the idle at something like 800 rpm with IAC unplugged and all electrical equipements and AC OFF (it is normal you will have a "Check engine" on with IAC disconnected).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Not_Rice4ws »</TD></TR><TR><TD CLASS="quote">i adjust the tension on my throttle cable when i want to bump the idle up.</TD></TR></TABLE>
That's not a great idea, it'll stretch your throttle cable, and wear out the little rubber stopper down on the pedal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattspivey »</TD></TR><TR><TD CLASS="quote">what do yall use to adjust it i cant find any thing to fit it allen wrentches screw drivers etc </TD></TR></TABLE>
umm, a flathead screwdriver. Are you looking at the right thing?
gabrielsousa
May 2, 2014 07:53 AM
asocallocal
Sep 23, 2010 06:20 PM
