Which is the best aftermarket b series oil pan?
Old Sep 12, 2004 | 09:59 AM
Code Blue's Avatar
Default Which is the best aftermarket b series oil pan?
just like the topic says, just wondering what the best aftermarket b series aluminum pan is, i remember people saying a few of them sucked because the oil return bungs sat below the oil level and kept blowing turbos, but i know there are a bunch of new companies offering the pans.
TIA
Jason
Old Sep 12, 2004 | 10:06 AM
EM1 MIKE's Avatar
Default Re: Which is the best aftermarket b series oil pan? (Code Blue)
<-- Moroso oil pan. I'm using pan #20901 and the oil pump pickup is #24011.
Modified by EM1 MIKE at 12:31 PM 9/12/2004
Old Sep 13, 2004 | 07:58 PM
Code Blue's Avatar
Default Re: Which is the best aftermarket b series oil pan? (EM1 MIKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1 MIKE &raquo;</TD></TR><TR><TD CLASS="quote">&lt;-- Moroso oil pan. I'm using pan #20901 and the oil pump pickup is #24011.
Modified by EM1 MIKE at 12:31 PM 9/12/2004</TD></TR></TABLE>
any problems with the oil? i heard horror stories about moroso pans and blowing turbo seals because the oil drain bung was too low
Old Sep 14, 2004 | 08:53 AM
White Smoke's Avatar
i my honda
Global Mod
Any particular reason you want an aluminum oil pan?
They tend to dent easy
Old Sep 14, 2004 | 09:13 AM
seen4ever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue &raquo;</TD></TR><TR><TD CLASS="quote">
any problems with the oil? i heard horror stories about moroso pans and blowing turbo seals because the oil drain bung was too low</TD></TR></TABLE>
that's only for people that use the low plug on the front, there is a plug at the top of the pan that is perfect for turbo drain.
Old Sep 14, 2004 | 10:47 AM
Code Blue's Avatar
Default Re: Which is the best aftermarket b series oil pan? (si2die4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">Any particular reason you want an aluminum oil pan?
even in the summer months, rust hurts in upstate ny.
plus, im going to have a 4 point brace underneith and that will be the first thing to scratch, a cheap 40 dollar investment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">
that's only for people that use the low plug on the front, there is a plug at the top of the pan that is perfect for turbo drain.</TD></TR></TABLE>
ahh ok that i didn't know, thanks
sikid111
Jan 31, 2019 07:14 PM
K20A2 5 lug EG
Aug 6, 2008 11:50 AM
crx_pimp
Sep 1, 2005 04:34 PM
Dragger817
Apr 24, 2003 10:41 PM
