Mini me problem, help appreciated!
Old Sep 11, 2004 | 01:52 PM
TurboHatch00's Avatar
Default Mini me problem, help appreciated!
I have just recentlly done a mini me swap. I had the 2000 dx setup and had to change to a p2p ecu. So I have a obdII ecu if i'm not mistaken. I need to know where the vtec pressure sensor would plug into the ecu. I've been stuck for so long on searches and I've even tried libraries. Please help!
Old Sep 12, 2004 | 02:46 PM
Default Re: Mini me problem, help appreciated! (XAllNewbX)
bump
Old Sep 12, 2004 | 09:20 PM
bump
Old Sep 13, 2004 | 08:42 AM
ttt
Old Sep 13, 2004 | 09:20 AM
bambam's Avatar
Try this link:
http://www.turbod16.com/viewtopic.php?t=3572
or this H-T thread:
https://honda-tech.com/zerothread?id=400013
the first is for 99-00 si's and the second is for P73's but they are both obd2 and they are both vtec...so they might help you.
Old Sep 13, 2004 | 03:57 PM
Default Re: (bambam)
thanks for the info, got the solenoid and pressure senor hooked up, but when i have the presure sensor hooked up and i try to start my car i blow a fuse!
Old Sep 14, 2004 | 10:22 AM
bambam's Avatar
well, which fuse?
Old Sep 14, 2004 | 09:22 PM
It's a relay fuse hooked up for the engine management control module. And it is hooked up to the fuse box.
Old Sep 15, 2004 | 01:05 PM
bambam's Avatar
Default Re: (XAllNewbX)
so you're blowing the ecu fuse? somethings not wired right. are you grounding your vtec pressure switch?
Old Sep 15, 2004 | 07:41 PM
the fuse i'm blowing is from the turbo kit which is a fuse coming from the fuse box power wire.
rlembitz
Dec 14, 2010 03:11 PM
crxdude
16
Jun 5, 2007 05:18 PM
MITSU_MaN
May 15, 2007 10:42 PM
Racewerkz
Dec 11, 2006 06:43 PM
