installing a tach
Old Sep 11, 2004 | 01:32 PM
Superman137's Avatar
Default installing a tach
I got a question for you I have a 5" tach and I'm wondering what would be the best place to hook it up I wanna know if I should hook it up to the ecu tach wire inside the car or do it under the hood I think it would be easier for me to hook it up inside the car instead of going under the hood.
Also this is a 92 Accord with jdm h22a swap in it
And another quick question i'm getting a code 41 which is an oxygen sensor should I get a universal sensor which is cheaper or get the factory sensor?
Old Sep 12, 2004 | 02:08 PM
TxTuner
Guest
Posts: n/a
Default Re: installing a tach (Superman137)
The best place I've found to hook it up is a little spot right next to the Muffler Bearing Housing If I'm correct your car already has a tach, why the **** do you want some big ******* tachometer (that's meant for old muscle cars which didn't come with tachs) staring you in the face??? Just so we can all make fun of you??? If that's the case, go ahead.
Old Sep 12, 2004 | 02:13 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superman137 &raquo;</TD></TR><TR><TD CLASS="quote">I wanna know if I should hook it up to the ecu tach wire inside the car or do it under the hood
And another quick question i'm getting a code 41 which is an oxygen sensor should I get a universal sensor which is cheaper or get the factory sensor?</TD></TR></TABLE>
You can either run it to the ECU RPM Signal wire, or to the distributor signal wire. As far as the o2 sensor, a BOSCH replacment would work fine. I wouldn't recommend a universal because most universal o2 sensors aren't heated o2s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">The best place I've found to hook it up is a little spot right next to the Muffler Bearing Housing</TD></TR></TABLE>
Old Sep 12, 2004 | 02:18 PM
TxTuner
Guest
Posts: n/a
Default Re: installing a tach (LSVTEC 91 Civic)
Goddamn ricers!!!
Old Sep 12, 2004 | 03:44 PM
H2290's Avatar
Default Re: installing a tach (TxTuner)
Man, you guys suck! Hey man, install the biggest one you can find. Seriously though I have a 90 Accord with an H22 and my fuel cutoff is at the end of the tach and my redline is pretty close.
I know the stock tach gets pretty far off but does it get worse the closer you get to the end of the tach? If so, then an aftermarket more accurate tach could be really useful for those swapped Accords.
Old Sep 17, 2004 | 08:01 AM
Default Re: installing a tach (H2290)
The only reason I got a tach is so I can no when I redline b/c I got a jdm h22a and I can relie on my stock tach. But thanks to ya'll all for ur help it's greatly appeciated
Old Sep 17, 2004 | 09:14 AM
BoostedH23Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">Goddamn ricers!!! </TD></TR></TABLE>
Exactly
Old Sep 17, 2004 | 09:58 AM
TOAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superman137 &raquo;</TD></TR><TR><TD CLASS="quote">The only reason I got a tach is so I can no when I redline b/c I got a jdm h22a and I can relie on my stock tach. But thanks to ya'll all for ur help it's greatly appeciated</TD></TR></TABLE>get a different tach... like i dunno... out of a car that came with an h22?
Old Sep 17, 2004 | 10:14 AM
FatJoe's Avatar
Default Re: installing a tach (TOAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOAB &raquo;</TD></TR><TR><TD CLASS="quote">get a different tach... like i dunno... out of a car that came with an h22?</TD></TR></TABLE>
fabricate a SH cluster into the accord....that would be bad
Old Sep 17, 2004 | 10:39 AM
H2290's Avatar
Default Re: installing a tach (FatJoe)
Has this ever been done? Don't the Preludes have that weird long dash rather than a little sphere in front of the driver? That may make it completely impossible in the first place. Somebody give it a stab and let us know what you come up with.
Old Sep 17, 2004 | 10:48 AM
FatJoe's Avatar
i think ive seen it done before... cant say for sure tho
Old Sep 17, 2004 | 11:18 AM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe &raquo;</TD></TR><TR><TD CLASS="quote">i think ive seen it done before... cant say for sure tho</TD></TR></TABLE>
i have seen it done....most likely at accordinglydone.com....they also did one of those "vtec engagment lights" things....looked crazy seeing an accord w/ orange OEM Honda gauges....
Old Sep 17, 2004 | 12:17 PM
Default Re: installing a tach (fw190bvi)
Draven8795
Feb 14, 2012 03:49 PM
dc2leftovers
Aug 22, 2007 10:50 PM
Nataku
May 29, 2006 08:13 AM
GUNNER666
Apr 7, 2004 07:55 PM
team2n1hatch
Jun 18, 2003 09:37 AM
