agx settings
Need to know more. Do you have any other aftermarket suspension parts? Have you messed with your ride height, or alignment settings? Have you tracked the car in any way to tell me what's going on? Real easy thing to do as long as your in a safe environment. Set the fronts all the way hard and the rears all the way soft. Drive hard. See what it does. Then do the opposite. Drive hard see what it does. Slowly adjust back to which ever way you prefer the suspension to handle. Personally I like the rear to come out a little under higher loads. Some people dial in a little understeer and let it come out to the edge of a corner.
Good luck. !
Good luck. !
Tru Dynamix
Jan 22, 2003 03:37 PM
