15.395@90.21 mph
Old Sep 11, 2004 | 08:18 AM
HBK's Avatar
HBK
Default 15.395@90.21 mph
Setup
88 CRX DX
Lowered
I/H/E
98 intake manifold
stock block/stock head with si cam
si tranny
PG7
R/t - .304
60' - 2.338
330 - 6.497
1/8 - 9.921
mph - 71.43
990 - 12.809
1/4 - 15.395
mph - 90.21
here comes the fun part - Apparently my alternator belt snapped a day or two ago, and I've been running on my battery. I didnt know, so i get to the track, run 5 times, park the car and shut it off, and it wont turn on. i look at the alternator, and theres no belt. Im like, huhhhhhhhh.....*long silence*, takes me a while to realize whats going on, call up big bro who failed to run, and he supplies me with a new belt, tools, and jumper cables, and in return he gets a free ticket in to watch, as the people felt bad for me and let him in for free. so we fix the car, and i get back in line. The battery took a long time to charge, so i left it idle a while, only thing is, now when i put it in 1st gear, it feels like its not in all the way, and the car will just rev instead of going, i have to play with it a lil to actually go, is this a synchro? or could it just be the trannny oil? im kinda pissed about it, but at the same time, i just ran a 15.3 with a stock dx motor...
Old Sep 11, 2004 | 08:27 AM
LSVTEC 91 Civic's Avatar
Banned
Where are the pics?
Old Sep 11, 2004 | 08:28 AM
NFM_Dm's Avatar
Default Re: (LSVTEC 91 Civic)
wit dpfi?
Old Sep 11, 2004 | 08:29 AM
HBK's Avatar
HBK
Default Re: (sekz)
mpfi with 98 y8 intake manifold
Old Sep 11, 2004 | 10:02 AM
crx_88_si's Avatar
Default Re: (B16Bomber)
wont be the syncro, 1st and reverse dont have them
check the linkage.
Old Sep 11, 2004 | 11:31 AM
HBK's Avatar
HBK
Default Re: (crx_88_si)
thanks cause sometimes now when i put it in 1st, itll get "sticky" and i have to throw it into reverse.
Old Sep 11, 2004 | 11:41 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: 15.395@90.21 mph (B16Bomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Bomber &raquo;</TD></TR><TR><TD CLASS="quote">i just ran a 15.3 with a stock dx motor... </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">mpfi with 98 y8 intake manifold</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">si cam</TD></TR></TABLE>
Hmmmmmm...........
Old Sep 11, 2004 | 12:24 PM
HBK's Avatar
HBK
Default Re: 15.395@90.21 mph (Mr Milano)
alrriiiiite, i get where your going with that, its not a STOCK motor, but for the most part, its pretty stock. I've seen guys with b16 swaps, zc swaps, ls swaps, running the same times. so its basically an A6, besides the 1.5l block. which is still awesome.
Old Sep 11, 2004 | 12:29 PM
MonkeyMagic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">wont be the syncro, 1st and reverse dont have them
check the linkage.</TD></TR></TABLE>
bullshit, 1st has a synchro... hence the pause and no grind when shifting into first while moving. most likely you broke a finger off the shift fork, or the sychro went out. both are common and would cause a nasty effort to place into first
but goddamn, 90mph for a stock motor?? thats just amazing!
Old Sep 11, 2004 | 12:56 PM
Bserieskllr's Avatar
nice times....get the 60's down and youll get a lower e.t.
Old Sep 11, 2004 | 02:59 PM
HBK's Avatar
HBK
Default Re: (MonkeyMagic)
ur telling me... I read 90 mph, and im like, wait a second, and check to make sure it was my car,
and about my 60 ft time, jeez its tough, im rolling on azenis with 20lbs, and i was either boggin or spinning, no in between. but yea, 90mph was my average trap speed.
i dont know what else to do with my motor, tonite im having a friend make me a test pipe for my cat, so that should help a bit, but other than that, im not gonna buy any parts for that motor, cause i have a y8 in the garage...
Old Sep 11, 2004 | 06:44 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
good job lil bro.
Old Sep 12, 2004 | 03:56 PM
EJ2-Fluffy's Avatar
Default Re: (91siredrex)
Any picture of your time slip?
-Jon
Old Sep 12, 2004 | 04:16 PM
green91's Avatar
how big of a difference did the Si cam make?
Old Sep 12, 2004 | 05:28 PM
-16V-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Bomber &raquo;</TD></TR><TR><TD CLASS="quote">mpfi with 98 y8 intake manifold</TD></TR></TABLE>
Did u notice a big difference with this mod?
Old Sep 12, 2004 | 06:27 PM
88 rex's Avatar
Default Re: (-16V-)
what's the advantage of the y8 mani over the a6 mani?
Old Sep 12, 2004 | 07:06 PM
Default Re: (88 rex)
well as we all know mpfi compared to dual point is like night and day.
the si cam is a lil wilder than the dx cam.
and i threw the y8 manifold on his car. its alot bigger and flows the best out of the d series oem intake manifolds.
Old Sep 12, 2004 | 07:30 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91siredrex &raquo;</TD></TR><TR><TD CLASS="quote">well as we all know mpfi compared to dual point is like night and day.
and i threw the y8 manifold on his car. its alot bigger and flows the best out of the d series oem intake manifolds.</TD></TR></TABLE>
yes, the SI cam is the best SOHC non vtec cam..... its hardly 'wild'
and the y8 has a larger plenum and fatter shorter runners which flows MUCH better.
good times on that DX man..... pretty damn impressive, what does the car weigh?
Old Sep 12, 2004 | 09:02 PM
well they weight in stock at 1920. hes got an integra swaybar, and integra rear brakes. hes prob weighing in at about 1950-2000 range
Original Boski
Nov 4, 2014 04:48 PM
chief smackahoe
Sep 30, 2013 09:54 PM
kdg123
Oct 29, 2012 01:26 PM
JDMgunmetalCRX
Apr 17, 2009 06:35 AM
PPen131
Aug 31, 2002 08:01 PM
