Need help on a all motor d16a6 set up
i have a d16 si motor in my crx and i wanted to know what would be the best street/drag race set-up for it and a reasonable cost im still in high school so i can spend too much in it so can someone help me out. thanks
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Here is my set-up.
88 D16A6
.50 over P29 pistons, swaintech coated top and skirts.
stock rods with ARP rod bolts
ACL main and rod bearings
ARP head studs.
mild P&P head 40 thou milled (end compression ratio is around 12:1)
Rocket/RM nonVTEC cam
ISKY valvetrain
ACT prolite flywheel and hyper clutch.
chikara header (because my old one cracked), BISI sometime in the future
stock induction system for now.
turboedit with NG48 ROM
MSD external coil with MSD wires and Rocket modified NGK colder sparkplugs
no 1/4 mile numbers as i am not interested in that and since the engine has not been tuned yet.
sometime in the future perhaps...
pretty fast set-up, loses traction in first and second at 7-8K RPM.
it idles lopey and runs rich at idle, and it needs around 97 octane to be happy
the set-up was not as cheap as i intended it, but over all it is a nice light stock looking engine.
stan
88 D16A6
ARP head studs.
ISKY valvetrain
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcfreak »</TD></TR><TR><TD CLASS="quote">any news about your setup..??dyno numbers..1/4 times slips
have not tuned the damn thing yet, it has been parked with a blown distributor for two weeks now.
gotta get it tuned and ready for october 22 though, i'll keep yo'all posted.
stan
</TD></TR></TABLE>have not tuned the damn thing yet, it has been parked with a blown distributor for two weeks now.
stan
damn stan you are running the EXACT same setup i am going to run on my A6, although I won't be milling the head that much.
What's the lift and duration on Rockets cam?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brol1k »</TD></TR><TR><TD CLASS="quote">no tuning=no power.get it tuned rite and then see if that is the answer to your problem!</TD></TR></TABLE>
Huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES »</TD></TR><TR><TD CLASS="quote">damn stan you are running the EXACT same setup i am going to run on my A6, although I won't be milling the head that much.
What's the lift and duration on Rockets cam?</TD></TR></TABLE>
don't remeber off the top of my head. i'll have to dig through my papers.
stan
Huh?
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D »</TD></TR><TR><TD CLASS="quote">
stan</TD></TR></TABLE>
let me know something when you find it please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D »</TD></TR><TR><TD CLASS="quote">Here is my set-up.
88 D16A6
ARP head studs.
ISKY valvetrain
stan
are you running the a6 intake manifold and TB? Your set, as said before, is real close to what I will be running. Keep us up to date.
88 D16A6
ARP head studs.
ISKY valvetrain
stan
Huh?
ull neva get it
Huh?
ull neva get it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by busychild »</TD></TR><TR><TD CLASS="quote">are you running the a6 intake manifold and TB? Your set, as said before, is real close to what I will be running. Keep us up to date.
stock intake and TB. ITBs in the works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brol1k »</TD></TR><TR><TD CLASS="quote">ull neva get it</TD></TR></TABLE>
are you talking to me?
stan
</TD></TR></TABLE>stock intake and TB. ITBs in the works.
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES »</TD></TR><TR><TD CLASS="quote">let me know something when you find it please.
ok here it is.
10.8mm lift. 207 duration at 0.050. 275 gross duration
directly from Robert.
stan
</TD></TR></TABLE>ok here it is.
stan
turboedit right now, SERIOUSLY considering OBD1 conversion.
or maybe even Megasquirt. we'll see how much interest i retain with this thing, since i have been concentrating on my Z
stan
stan
T25 civic
Mar 17, 2007 06:35 AM
