if i change my tranny oil will it make it shift better?
Old Sep 10, 2004 | 07:16 PM
BlazeTeck2000's Avatar
Default if i change my tranny oil will it make it shift better?
i have 491,098 and i never changed the oil in the tranny does anyone know if it will make it shift better if i change it ??? i change my oil from car every 2,500
Old Sep 11, 2004 | 02:38 AM
edd001's Avatar
Default Re: if i change my tranny oil will it make it shift better? (BlazeTeck2000)
if you have never chaged the oil then yes it probably will.
change it as you might find it is very dirty.
if it is manual it should be chaged about 75000 miles i think.
if it is auto it should be changed every 45000 miles.
Old Sep 11, 2004 | 03:44 AM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlazeTeck2000 &raquo;</TD></TR><TR><TD CLASS="quote">i have 491,098 and i never changed the oil in the tranny does anyone know if it will make it shift better if i change it ??? i change my oil from car every 2,500 </TD></TR></TABLE>
If it's shifting rough and you've never changed it after 1,000,000,000 miles. The damage is going to be irreversible. But you might as well change it anyway. Couldn't hurt to try.
Old Sep 11, 2004 | 08:43 AM
Default Re: if i change my tranny oil will it make it shift better? (Escobar)
the car shifts fine when cars been running for 15 min ... when you first turn it on and its cold and i put it on reverse it does it mad hard but after 15 min it wont do it as hard ...when im going staight it takes gears hard also but after a while its normal
Old Sep 11, 2004 | 09:02 AM
TOAB's Avatar
if its an AT dont change the transmission fluid... you missed the mark a long time ago, and it'll only make the problem worse. start saving for a new transmission.
Old Sep 11, 2004 | 09:16 AM
Default Re: (TOAB)
what is the mark that it should have been done?
Old Sep 11, 2004 | 09:27 AM
m0t0rhead's Avatar
Default Re: (BlazeTeck2000)
Every 30,000 miles.
Old Sep 11, 2004 | 09:34 AM
Default Re: (Escobar)
Nyc Here i can get it done for $100 is that good ?
Old Sep 11, 2004 | 11:02 AM
AznPrideYo's Avatar
No.. it takes all of 5 minutes.
Old Sep 11, 2004 | 02:16 PM
TOAB's Avatar
im telling ya... use the search feature. this has been covered before... if youve gone way past the 30k mark youre fucked. lol
edit: well not fucked, but changing the fluid will do more harm than good.
Old Sep 11, 2004 | 03:45 PM
H22A-AllMotor's Avatar
Default Re: (TOAB)
How did you neglect to maintain your car so much....
Old Sep 11, 2004 | 07:27 PM
Justin Klemgold's Avatar
Default Re: (TOAB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOAB &raquo;</TD></TR><TR><TD CLASS="quote">im telling ya... use the search feature. this has been covered before... if youve gone way past the 30k mark youre fucked. lol
edit: well not fucked, but changing the fluid will do more harm than good.</TD></TR></TABLE>
252k on my auto tranny...the original owner last changed it at around 125,000...I changed it when I bought it at 242,000, and nothing is wrong....it shifts better...I dno't believe that "if you've gone that far, forget it, it will do more harm than good"....that's an old myth IMHO.
Old Sep 11, 2004 | 10:30 PM
89_LXi's Avatar
Default Re: (Justin Klemgold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Klemgold &raquo;</TD></TR><TR><TD CLASS="quote">
252k on my auto tranny...the original owner last changed it at around 125,000...I changed it when I bought it at 242,000, and nothing is wrong....it shifts better...I dno't believe that "if you've gone that far, forget it, it will do more harm than good"....that's an old myth IMHO.</TD></TR></TABLE>
Actually though, it is indeed true. Same goes for master cylinders, p/s racks, and in some cases even calipers and wheel cylinders. What happens is when the fluid (whether it be tranny, power steering, or brake) gets dirty and contaminated with various particles, these particles rub and rub on the pistons and seals and such, which etches small scratches into the surface. As long as the old dirty fluid is in there, those dirt particles actually act as a 'plug' for the scratches so it will still seal pretty good (or in a tranny's case, grip pretty good). Now you flush the dirty fluid out and all the dirt particles go with it, now there's nothing to help plug and seal the damage done, and the clean fluid leaks right through the imperfections left. Remember, these dirt particles are being forced around under pressure (pressure in brake lines and high pressure p/s line and rack usually reach nearly 2000 psi), so it doesn't take that much or that long to do damage. In a trannys case, the contamination usually comes from the clutch packs wearing (it's a friction material just like a clutch, brake pads, etc), which when mixed with high pressure fluid acts just as sandpaper, and it's all downhill from there. That's why it's soooooo important to change all your fluids regularly!!
Old Sep 12, 2004 | 06:13 AM
If it were up to me, I would have done it on time...other than the tranny fluid, the car was very meticulously cared for...with all necessary changes done...I'm 10k later and my tranny is still fine...*knocks on wood*
Old Sep 12, 2004 | 10:02 AM
TOAB's Avatar
Default Re: (89_LXi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89_LXi &raquo;</TD></TR><TR><TD CLASS="quote">Actually though, it is indeed true. Same goes for master cylinders, p/s racks, and in some cases even calipers and wheel cylinders. What happens is when the fluid (whether it be tranny, power steering, or brake) gets dirty and contaminated with various particles, these particles rub and rub on the pistons and seals and such, which etches small scratches into the surface. As long as the old dirty fluid is in there, those dirt particles actually act as a 'plug' for the scratches so it will still seal pretty good (or in a tranny's case, grip pretty good). Now you flush the dirty fluid out and all the dirt particles go with it, now there's nothing to help plug and seal the damage done, and the clean fluid leaks right through the imperfections left. Remember, these dirt particles are being forced around under pressure (pressure in brake lines and high pressure p/s line and rack usually reach nearly 2000 psi), so it doesn't take that much or that long to do damage. In a trannys case, the contamination usually comes from the clutch packs wearing (it's a friction material just like a clutch, brake pads, etc), which when mixed with high pressure fluid acts just as sandpaper, and it's all downhill from there. That's why it's soooooo important to change all your fluids regularly!!</TD></TR></TABLE>
Old Sep 13, 2004 | 05:56 PM
A340600's Avatar
If you have an auto, change it every 20K miles. Else, you might lose your tranny. 2K to replace.
If you have a stick, you have to change the gear oil.
Don't mess with these things. You will get bitten hard on the a$$ if you neglect your transmission.
I don't want you to lose your car, really. I know people who have.
accord03coupe
Honda S2000
Apr 8, 2008 06:41 PM
yobbr5
Honda Civic (2006 - 2015)
Nov 3, 2007 10:37 PM
coupon
Aug 28, 2005 12:19 PM
peel17
Jun 28, 2005 01:10 PM
t0p_sh0tta
Mar 30, 2004 04:43 PM
