**help needed with wiring **
Old Sep 10, 2004 | 07:00 PM
RiceInspiredFireFighter's Avatar
Default **help needed with wiring **
im looking at an MTX sledgehammer system...its cheap and does the job...on my mini-budget. I have about 600 bucks. I want the sub in box, inline fuse, wire, coil, amp, and head unit. My question is...WHO THE HECK DO I GET NEGATIVE FROM THE AMP. I mean every diagram shows speaker set up but not the negative side of the setup. Im comin off as a noob..cuz for the most part I am in the wiring field. I am looking at a 140 dollar MTX to tag the beats on the sludgehammer. Lord some one help me plz!
Old Sep 11, 2004 | 07:35 AM
fcm's Avatar
fcm
Old Fart
Default Re: **help needed with wiring ** (RiceInspiredFireFighter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceInspiredFireFighter &raquo;</TD></TR><TR><TD CLASS="quote">im looking at an MTX sledgehammer system...its cheap and does the job...on my mini-budget. I have about 600 bucks. I want the sub in box, inline fuse, wire, coil, amp, and head unit. My question is...WHO THE HECK DO I GET NEGATIVE FROM THE AMP. I mean every diagram shows speaker set up but not the negative side of the setup. Im comin off as a noob..cuz for the most part I am in the wiring field. I am looking at a 140 dollar MTX to tag the beats on the sludgehammer. Lord some one help me plz!</TD></TR></TABLE> If you mean the 12v- for the amp. ground the amp as close to amp as you can, you will want the ring term. to make contact with the floorpan of the car, clean off all paint,you want bare metal, use a seat or seatbelt bolt.
Don't forget to upgrade,[add] grounds under hood,[batt. alt.]. 94
Old Sep 11, 2004 | 05:41 PM
Odessa's Avatar
Default Re: **help needed with wiring ** (fcm)
I attached my ground to the rear right shock bolt...but sand off the paint first.
phayzeone
Audio / Security / Video
10
Jan 31, 2007 05:10 PM
doggworld1233
16
May 15, 2006 02:26 AM
rollin92
Nov 22, 2005 12:33 PM
8point6
16
Apr 21, 2005 11:50 AM
Starrman85
Apr 15, 2003 04:24 PM
