Component wiring - Alphasonik components to Kicker amplifier
Old Jan 3, 2007 | 04:00 PM
phayzeone's Avatar
Default Component wiring - Alphasonik components to Kicker amplifier
I want to know if my components are wired correctly. The way I have it set up is each channel from the amplifier is connected to each crossover (- & +).
My question is what is the correct way to wire the components to get 125 watts RMS x 2 at 2 ohms from the amplifier. The way I currently have it wired, I believe I'm only getting 75 watts RMS x 2 at 4 ohms.
Setup:
Kicker KX250.2
250 watts RMS x 1 in bridged mode
Alphasonik PCZ65
4 Ohm impedance
Power Handling: 120 Watts RMS
The way I currently have it wired:
...but I think it should be wired like this:
Old Jan 3, 2007 | 04:43 PM
pghz_last_don's Avatar
Default Re: Component wiring - Alphasonik components to Kicker amplifier (phayzeone)
single voice coil. or dual?
Old Jan 3, 2007 | 04:49 PM
phayzeone's Avatar
Default Re: Component wiring - Alphasonik components to Kicker amplifier (pghz_last_don)
Not sure. Here are the specs:
• Polypropylene-Injected Cone
• Butyl Rubber Surround
• 2-Layer Hi-Temp ASV Voice Coil
• Oversized Poly-Woven Damper
• Proprietary Heavy-Gauge Coated Steel Frame
• Plated Back Plate with Jewel Cut Badge
• 3600 Swivel Tweeter Design
• 1 Pair Tweeter Surface Mount Housings
• 1 Pair Tweeter Flush Mount Housings
• 1 Pair 12dB/Octave Crossover Networks
• 4-ohm Impedance
• Complete Mounting Hardware
with Grilles and Templates
Old Jan 3, 2007 | 04:53 PM
ok, if they are single voice coil then the 1st diag. is the correct way BUT if they are dual then thats a whole new story
Old Jan 3, 2007 | 04:57 PM
nsxxtreme's Avatar
You will only get a 2 ohm load with those speakers. Either buy 2 ohm mids and tweets or add more speakers.
Old Jan 3, 2007 | 04:59 PM
phayzeone's Avatar
Default Re: (nsxxtreme)
So am I getting 125 watts RMS x 2 at 2 ohms with the first diagram?
Old Jan 3, 2007 | 05:08 PM
fcm's Avatar
fcm
Old Fart
Default Re: (phayzeone)
You are not.
The amp "sees" 4 ohms, both sets of wires in 2nd diagram are going to the same VC, it is just a double terminal.
BTW your probably better off with 2x75W as I believe the 120W power handling of the speaker is it's max power. 94
Old Jan 3, 2007 | 05:12 PM
phayzeone's Avatar
Default Re: (fcm)
Got it. Thanks!
Old Jan 3, 2007 | 09:05 PM
nsxxtreme's Avatar
lol woops mistyped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">You will only get a 2 ohm load with those speakers. Either buy 2 ohm mids and tweets or add more speakers.</TD></TR></TABLE>
meant to type You will only get a 4 ohm load with those speakers. You can tell buy my last statement what I meant to say.
Old Jan 31, 2007 | 09:14 AM
phayzeone's Avatar
Default Re: Component wiring - Alphasonik components to Kicker amplifier (Miss Type R Tia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miss Type R Tia &raquo;</TD></TR><TR><TD CLASS="quote">lol...nice wire drawing....artist we are! gl on midterms next week dude </TD></TR></TABLE>
clownin! haha. good luck to you too
Old Jan 31, 2007 | 05:10 PM
phayzeone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miss Type R Tia &raquo;</TD></TR><TR><TD CLASS="quote">hahahahah no its nice! see u around the hallways lol. </TD></TR></TABLE>
I don't even know how you look. haha
1bar
Audio / Security / Video
Dec 18, 2005 08:06 AM
8point6
16
Apr 21, 2005 11:50 AM
GroundZer0 336
Apr 17, 2004 08:54 AM
HondaHanger
Feb 10, 2003 02:25 PM
teq1816
Sep 12, 2001 10:47 PM
