Main caps/bearing question.
i am currently stroking my gsr, with an ls crank/rods and i need to get new main bearings....so do i order bearings for a b18b, or a b18c1?
there are numbers on the crank and block for the main bearings if you are using OEM...There is a chart that you have to use to identify the color...As for the rod if you are using the aftermarket rod. just get the Green bearing from honda.
eg4life1202
11
Jan 14, 2007 09:17 AM
