is it necessary to aggressively set your timing to the verge of knocking??....
Old Sep 10, 2004 | 10:14 AM
Cowboy's Avatar
Default is it necessary to aggressively set your timing to the verge of knocking??....
i've heard somewhere that it may not be beneficial to set timing so agressive that it's right under the verge of knocking. (not only to save the engine, but there's no significant horsepower gain)
WITHOUT A DYNO, the only way i know to tuning the iginition portion of the engine is to advance timing until you hear knocking (obviously not groups at a time but per zone) and then retard 1 degree. is this the best way to optimize horsepower?
for some motors, i've heard that there are no horsepower gain past a certain point. and it could be way below the threshold so there's no reason to set the timing that far. or is the ONLY way to test this theory is to compar different timing senerios at the dyno?
i'll eventually run the car on the dyno, but i want to set everything up so i can maximize the time i have there.
thoughts? comments?
Old Sep 10, 2004 | 12:13 PM
Cowboy's Avatar
bump
Old Sep 10, 2004 | 12:33 PM
Sack Master's Avatar
Default Re: (Cowboy)
Dude if you can hear knocking(I'm presuming you are not using a stethoscope or the famous screwdriver trick) then your car is probably not runnning very well at all.
Old Sep 10, 2004 | 02:57 PM
The-LS's Avatar
Default Re: is it necessary to aggressively set your timing to the verge of knocking??.... (Cowboy)
check out http://www.boosted-hybrid.com and read up on the forums. Read up on as much as you can on tuning. Its best to read all about standalone tuning than to just ask 1 question that you have about tuning. Because you will never learn anything NEW since you won't know better to ask questions about things you may not even know exists.
BABY NSX
Apr 6, 2007 03:25 PM
jmal1919
Jun 1, 2005 12:39 PM
JayDM_lsvtec
Mar 15, 2005 08:01 AM
hmongboyLS
May 13, 2004 11:36 PM
brownman72000
Jun 8, 2002 07:33 AM
