OEM bearings with Aftermarket rods?
Old Sep 9, 2004 | 10:48 PM
itralex's Avatar
Default OEM bearings with Aftermarket rods?
I'm gonna be buying some OEM bearings from Len sometime soon
i just want to know since that i am swapping rods will the size of the bearings change cause the rods changed
Old Sep 9, 2004 | 11:41 PM
110 South's Avatar
Default Re: OEM bearings with Aftermarket rods? (HypeR1004)
Yes,
You will have to measure the inner diameter of the rods big-end so you can size your bearings accordingly.
-Brandon
Old Sep 10, 2004 | 05:19 PM
itralex's Avatar
Default Re: OEM bearings with Aftermarket rods? (110 South)
once measured, how do i know which OEM bearing to use?
Old Sep 10, 2004 | 05:44 PM
Pondus's Avatar
This might be useful info : https://honda-tech.com/zerothread?id=715490
Old Sep 10, 2004 | 05:56 PM
DavidR's Avatar
Default Re: OEM bearings with Aftermarket rods? (Pondus)
Yup, just the post to refer to. I would recommend ONLY honda rod and main beaings, as you can get exactly the tolerance you want! Sure, other bearings cost less, but you don't see the V8 guys resizing thier rods and mains to fit those, now do you? (ie. Eagle and many other manufactures fit V8 rods and cranks to fit Honda bearings).
Old Sep 11, 2004 | 03:16 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: OEM bearings with Aftermarket rods? (DavidR)
nothing beats OEM stuff (Bearings, seals, gaskets, blah blah)
bnmm
Jan 9, 2011 08:32 PM
b20vtech
Feb 21, 2006 07:57 PM
itralex
Sep 10, 2004 06:12 PM
S88HON
Jul 22, 2004 10:48 AM
EKweezy
Oct 8, 2003 10:09 AM
