Oil line question
Hey guys I'm having a really hard time putting my oil lines together. I bought some oil line from fast turbo however I having a really hard time putting the fittings on the metal anodized fitting on the drain lines. Do yall have any tips. Im begining to feel retarded. Please help me out. Thanks
Jason
Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamartin0519 »</TD></TR><TR><TD CLASS="quote">Hey guys I'm having a really hard time putting my oil lines together. I bought some oil line from fast turbo however I having a really hard time putting the fittings on the metal anodized fitting on the drain lines. Do yall have any tips. Im begining to feel retarded. Please help me out. Thanks
Jason</TD></TR></TABLE>
Which drain kit did you buy? The push fit or stainless steel?
I have the push fit drain line and it's hard to get on there but it should slide on with a little pursuasion...try putting a little oil around the end of the rubber and see if that helps...if you have the push fit that is
Try heating the rubber hose in boiling water, that may loosen it up so that it can be pushed over the fitting. Sorry if thats not the problem, I dont quite understand.
Wrap masking tape around the line before you cut it, the cut the section to length in the middle of the tape, then put some oil on it. Put the fitting in a vise and push the hose into it. Twisting the hose as you push helps as well.
