whats the best trans for a b20 vtec swap in a integra
Old Sep 9, 2004 | 07:25 PM
b20vtec+boost=v8 killa's Avatar
Default whats the best trans for a b20 vtec swap in a integra
hey guys gotta question whats your opinion
whats the best trans for a b20 vtec swap in a integra???
money is not a big problem but dont everybody say itr trans either
give me a honest opinion
Old Sep 9, 2004 | 07:52 PM
SiB16A's Avatar
Default Re: whats the best trans for a b20 vtec swap in a integra (b20vtec+boost=v8 killa)
got the money then ITR with lsd and 4.7 final drive. B16a trannys are also fast revving trannys. Driving on the highway with a b16 tranny, youll be at a high rpm going 80 cause or shorter gears. gsr tranny has a tad bit of longer gear then b16 trannys and ls had the longest gears out of all. So you do the math
Old Sep 9, 2004 | 08:21 PM
Default Re: whats the best trans for a b20 vtec swap in a integra (SiB16a)
so if i have a gsr tranny should i go ahead and put it on or spend money and get a itr trans
Old Sep 9, 2004 | 08:41 PM
NFMS-1's Avatar
You can leave the GSR tranny on while you save money for a CTR/ITR tranny w/ built in lsd
Or--- You can machine work your GSR tranny with custom differentials and buy your own LSD.....
Old Sep 9, 2004 | 10:31 PM
GetawayInMoscow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16a &raquo;</TD></TR><TR><TD CLASS="quote">got the money then ITR with lsd and 4.7 final drive. B16a trannys are also fast revving trannys. Driving on the highway with a b16 tranny, youll be at a high rpm going 80 cause or shorter gears. gsr tranny has a tad bit of longer gear then b16 trannys and ls had the longest gears out of all. So you do the math
How does a tranny make you rev faster?
Ive heard that b16 trannys arent as strong as the rest of the b series family, but that might be bs. I would personally go with a 98 JDM ITR if you can find it. It will be $$$ though...
Old Sep 10, 2004 | 12:41 AM
Default Re: whats the best trans for a b20 vtec swap in a integra (GetawayinMoscow)
well my gsr tranny is on my gsr which is going into a hatchback any body have a itr trans lying around they wanna sell
Old Sep 10, 2004 | 02:40 AM
LSvtec03's Avatar
i think you'd be happy with the gsr, especially if it's your daily driver, and your on the highway. much more comfortable/ better gas mileage than the itr.
Old Sep 10, 2004 | 11:04 AM
does it make you rev faster just has shorter gears
Old Sep 10, 2004 | 03:46 PM
b20vtecv8killer's Avatar
thanks for copyng my user name boosstardaa
Old Sep 11, 2004 | 12:18 PM
HONDA_TYPE_R's Avatar
Default Re: whats the best trans for a b20 vtec swap in a integra (b20vtecv8killer)
Chuckle...that's funny. LSD=Limited Slip Differential. The ITR tranny comes stock with an excellent lsd. The ITR trannies come in 2 different types...one is the 96-97 spec which has 4.44 final drive, the other is the 98-00 with 4.785 final drive. I believe the 4.44 one's labeled N3E and the 4.785 is lableled J4D. The early cable b-series trannies are a bit more fragile than the later hydro trannies from what I have seen and heard. It's mostly to do with the synchro's. If you are worried about chewing up your gas on the highway with a high final drive tranny, either don't mod your car (you burn more gas with mods anyways) or get the LS tranny with a 4.2 final drive. Go to http://www.hondaswap.com . They have a list of tranny gears. The GSR tranny is great, but it does not have an LSD. For the cost, buying an ITR tranny with LSD already installed is probably your best bet. Getting a LSD installed in your gsr tranny will be costly. Especially the lsd itself. A good LSD from KAAZ, Quaife, ATS runs around $900, plus install. A honda oem lsd diff is about $400 on here. Save up for the ITR tranny, and then sell your GSR tranny once you've bought the ITR tranny.
Old Sep 11, 2004 | 12:33 PM
Kendall's Avatar
I think Len still has a USDM ITR tranny laying around. Shoot him a PM.
Regarding gear ratios, the ITR/CTR/B16 tranny's all have the same gear ratios with the exception of the 98 spec JDM ITR tranny which has a GSR 4th and 5th gear and a 4.785 final drive. The GSR tranny has longer gears than the B16 tranny and the LS tranny has longer gears than the GSR tranny. The LSD that comes stock in the ITR/CTR is a helical unit and is much more effective than the viscous unit found in some JDM B16 and GSR tranny's.
Old Sep 11, 2004 | 12:34 PM
Kendall's Avatar
Default Re: whats the best trans for a b20 vtec swap in a integra (HONDA_TYPE_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">I believe the 4.44 one's labeled N3E and the 4.785 is lableled J4D.</TD></TR></TABLE>
No, you have it backwards, the 96 spec with the 4.4 is labeled J4D and the 98 spec with the 4.785 is labeled N3E.
Old Sep 11, 2004 | 03:08 PM
Default Re: whats the best trans for a b20 vtec swap in a integra (Kendall)
You know how many times I keep ******* that one up? It boggles me. Brain's too full of useless knowledge...I guess I'm discarding important info to retain the useless stuff?! Thanks for the info. I hope I remember next time.
Old Sep 11, 2004 | 03:35 PM
mEr's Avatar
mEr
i would go w/ the GSR tranny, its a good median between shorter/longer gearing...
Old Sep 11, 2004 | 04:51 PM
maybe i should get the sticker of my integra thats been on there for about 9 months i guess you should have copyrighted that name
Old Sep 11, 2004 | 05:49 PM
SiB16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayinMoscow &raquo;</TD></TR><TR><TD CLASS="quote">
Ive heard that b16 trannys arent as strong as the rest of the b series family, but that might be bs. I would personally go with a 98 JDM ITR if you can find it. It will be $$$ though...</TD></TR></TABLE>
sorry i didnt mean it in that way. I meant SHORT gear higher revs driving around.
You have HEARD that b16 trannys arent strong what is the definition of STRONG? Then why do the guys on here with ls motors swap there tranny out for a b16 tranny over a gsr? because it has shorter gears than a gsr...then it all leads back to preference and where you wanna go with it. For drag, daily driver, if you want to save gas or not, highway battles, and so on.
Old Sep 11, 2004 | 05:54 PM
SiB16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">Chuckle...that's funny. LSD=Limited Slip Differential. The ITR tranny comes stock with an excellent lsd. The ITR trannies come in 2 different types...one is the 96-97 spec which has 4.44 final drive, the other is the 98-00 with 4.785 final drive. I believe the 4.44 one's labeled N3E and the 4.785 is lableled J4D. The early cable b-series trannies are a bit more fragile than the later hydro trannies from what I have seen and heard. It's mostly to do with the synchro's. If you are worried about chewing up your gas on the highway with a high final drive tranny, either don't mod your car (you burn more gas with mods anyways) or get the LS tranny with a 4.2 final drive. Go to http://www.hondaswap.com . They have a list of tranny gears. The GSR tranny is great, but it does not have an LSD. For the cost, buying an ITR tranny with LSD already installed is probably your best bet. Getting a LSD installed in your gsr tranny will be costly. Especially the lsd itself. A good LSD from KAAZ, Quaife, ATS runs around $900, plus install. A honda oem lsd diff is about $400 on here. Save up for the ITR tranny, and then sell your GSR tranny once you've bought the ITR tranny.</TD></TR></TABLE>
I believe the 4.44 one's labeled N3E and the 4.785 is lableled J4D other way around
Old Sep 11, 2004 | 08:07 PM
jaydeemmmm's Avatar
What kind of clutch will you be running? I heard some ITR trannies aren't as efficient with certain clutches. Only what I heard. I always planned on running the R tranny anyways. It'll be nice to have the LSD.
Old Sep 11, 2004 | 09:50 PM
That's it...I'm asking my friend...J4D is the 98 and up spec...he has one on his ITR swap.
Old Sep 11, 2004 | 11:52 PM
Nexx's Avatar
What's the Final Drive for a 99-00 Civic b16 tranny? 4.4?
Old Sep 12, 2004 | 11:27 AM
Default Re: whats the best trans for a b20 vtec swap in a integra (Nexx)
they have a graph of all the gear ratios for Honda trannies. I believe you have the S4C...it should be a 4.44 tranny.
GSARR01
Nov 1, 2005 12:36 PM
WNYAccordLX
Sep 24, 2004 01:14 PM
hurleyboarder21
Sep 16, 2004 07:53 AM
Calavera
Jan 9, 2003 07:43 AM
SIRX
Sep 30, 2002 12:33 PM
