How do I know it is time for new rotors?
when they are warped... does ur brake pedal vibrate when you press it? does your car shudder as you come to a stop? those are 2 symptoms of either knowing you need them turned or new ones all together
You need new rotors when you cannot hone/grind them down anymore past a certain safe level (shops know these levels per rotor/car). As far as the shudder after you wash your car its just old pads/rotor and water has gotten into the brakes and that rusty film is on the rotors (normal).
FYI, my front rotors lasted 120K miles.
You need new ones when you take it in and they tell you that they can't get a good enough scrape on the lathe.
Then, you get new ones. Otherwise, just keep on changing the pads and doing the scrapes.
if it only makes noise & shake AFTER you wash the car and it goes back to normal after a few times braking then THAT IS NORMAL!
when you are washing your car you are spraying lots of water on the rotors, which in turn rust.
after you brake a few times the rust comes off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeOPS »</TD></TR><TR><TD CLASS="quote">I might be replacing mine soon, how much for new rotors+pads on average?</TD></TR></TABLE>
Depends on car, all disc/disc and drum etc.
https://honda-tech.com/zerothread?id=961351
This guy has really good prices
My setup will consist of brembo blanks, axxis pads and SS brake lines he had a VERY nice price
I just got pads/rotors installed.. 400 dollars.. honda parts. I didnt want aftermarket, considering the stock rotors lasted 199k miles..
and after watching them bang to get them off.. i'm glad i didnt change them myself..
