Best fuel and injector cleaner?
Old Sep 9, 2004 | 05:55 PM
JinDIESEL's Avatar
Default which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil?
Old Sep 9, 2004 | 05:56 PM
Opie's Avatar
The kind that doesn't care what oil you use
Old Sep 9, 2004 | 06:00 PM
slammed_93_hatch's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (JinDIESEL)
i have found threw "search" that BG44K kicks ***, some people say its the same as the techron concentrate some say its not
Old Sep 9, 2004 | 06:07 PM
Nishant's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (slammed_93_hatch)
i used red line...was 6 bucks at pep boys
Old Sep 9, 2004 | 06:35 PM
KOALA YUMMIES's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (Nishant)
Used Chevron most of the time, STP was highly reccomended too. Just based off of what I've heard from friends and whatnot. I dont do it too often.
Old Sep 9, 2004 | 06:48 PM
Two_K Si's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (KOALA YUMMIES)
Fuel power is what i use. 2 oz's every fill up is the dosage. I prefer this regiment rather than just dumping a bottle of cleaner every 3k or so. I seem to be getting a little better mileage to boot.
Old Sep 9, 2004 | 06:59 PM
Batoutahell's Avatar
STP = free t-shirt.
And this is a hard decision, why?
Old Sep 9, 2004 | 07:05 PM
sil's Avatar
sil
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (Batoutahell)
because there are so many choices.. many of which probably don't work.. but both redline and techron are great.... check out bobistheoilguy.com
Old Sep 9, 2004 | 07:07 PM
.RJ's Avatar
.RJ
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (sil)
Motul Fuel System Cleaner
http://www.hmsmotorsport.com - where I order all my Motul bling, great service.
Old Sep 9, 2004 | 08:04 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Motul Fuel System Cleaner
http://www.hmsmotorsport.com - where I order all my Motul bling, great service.</TD></TR></TABLE>
How do you like it?
Chevron works well for me
Old Sep 9, 2004 | 08:15 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (FrostyDC4)
At work we sell and use an injector cleaner that acutally does work... it is not an additive to your gas tank.
The cleaner we use is in a compressed can similar to a spray paint can. The vehicle runs off of this bottle until it runs out.
Basically you remove the fuel pump fuses, run the vehicle out of the gas left in the rail and lines...then you remove the fuel line from the rail...hook up your regulator and can of injector cleaner and start the vehicle....cycle it through different rpm ranges then let it idle...we have tested the injectors and found they flow more after doing this procedure.
I dont remember the brand name. You might be able to find it online.
Old Sep 9, 2004 | 08:18 PM
[HrZn]4life's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (v-attack)
I've heard that techron is the best and I try to only use Chevron gas with techron... but last time I pulled my head I still had a good amount of carbon buildup around my valves.
Old Sep 9, 2004 | 08:56 PM
kim_2_da_chee's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? ([HrZn]4life)
Do these fuel additive "injection cleaners" really make that much of a difference? I always thought that using high octane fuel already cleans out the system from carbon build up on injectors and valves? I use 94 octane every time i fill up. What advantage do these cleaners have over high octane fuel?
Old Sep 9, 2004 | 09:25 PM
SLCTyper's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (kim_2_da_chee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee &raquo;</TD></TR><TR><TD CLASS="quote">Do these fuel additive "injection cleaners" really make that much of a difference? I always thought that using high octane fuel already cleans out the system from carbon build up on injectors and valves? I use 94 octane every time i fill up. What advantage do these cleaners have over high octane fuel?</TD></TR></TABLE>
Higher octane can potentially leave fewer carbon deposits but doesn't do anything by itself to clean injectors or valves. That's the purpose of additives like Techron.
Old Sep 9, 2004 | 10:11 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (SLCTyper)
CD2 Fuel Treatment
best 4 dollars
Old Sep 9, 2004 | 10:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLCTyper &raquo;</TD></TR><TR><TD CLASS="quote">
Higher octane can potentially leave fewer carbon deposits but doesn't do anything by itself to clean injectors or valves. That's the purpose of additives like Techron.</TD></TR></TABLE>
Roger
Old Sep 9, 2004 | 10:36 PM
ejprimo's Avatar
chevron gas
redline fuel cleaner or fuel power or chevron techron.
(proguard is not the techron concentarte.)
Old Sep 10, 2004 | 03:40 AM
DontBlink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote"> BG44K </TD></TR></TABLE>
good stuff, i been useing this for years, its just a little on the expensive side.
Old Sep 10, 2004 | 04:52 AM
Enrikez's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (DontBlink)
Lucas
Old Sep 10, 2004 | 05:13 AM
B18CXr's Avatar
Berryman's B12 is hands down the best, no question.
Old Sep 10, 2004 | 06:25 AM
pyromaster's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (Two_K Si)
That's what I use too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">Fuel power is what i use. 2 oz's every fill up is the dosage. I prefer this regiment rather than just dumping a bottle of cleaner every 3k or so. I seem to be getting a little better mileage to boot. </TD></TR></TABLE>
Old Sep 10, 2004 | 07:03 AM
tnord's Avatar
Default Re: which fuel and injector cleaner brand is best with castrol gtx 10w-30 oil? (pyromaster)
Old Sep 10, 2004 | 02:48 PM
Enrikez's Avatar
Default Re: which fuel and injector cleaner brand is best (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">Berryman's B12 is hands down the best, no question.</TD></TR></TABLE>
also the only one that contains acetone.
Lucas.
Old Sep 10, 2004 | 03:37 PM
Padawan's Avatar
Darth ModerVader
Another alternative some of you might want to consider if you're concerned about thoroughly cleaning your injectors is sending them out and having them professionally serviced. There are numerous shops you can locate online that will perform a complete cleaning and servicing for ~$50 total. In my opinion it's quite a good deal when you consider the cost of a few bottles of some of the high-end injector cleaners. Doing this perhaps every other year (or even yearly) in conjunction with running some of the inexpensive off-the-shelf fuel system cleaners would most likely keep your injectors in excellent shape.
Here is a link to the shop that recently serviced the Prelude injectors being used in my brother's setup - WitchHunter Performance
Old Sep 10, 2004 | 04:01 PM
Vu's Avatar
Vu
Using a higher octane fuel than your car need usually leaves more carbon deposits, not less. If your car can't efficiently burn that extra fuel, than it will create some carbon buildup.
