Protecting/rerouting a/c lines for DRAG turbo kit
Hello, I have the kit listed above and ran it since '99. However, a year after my kit the a/c lines were destroyed with a combination of chafing against the compressor housing and upper i/c piping. I'd like to know if any of you guys had this problem and remedied it with some type of thermo-tec wrap. Since they're hard lines, has anyone replaced them with custom an lines with custom adaptors coming from the a/c compressor? I'm getting old and I'd like my GS-R to be more civil with the a/c. Although I am exploring the option of getting a different manifold (I'd like to stay with this one, hasn't let me down for four years) but if I can keep my current setup, it'd be nice.
Thanks in advance.
Thanks in advance.
Buy a hose that's high temp, cut the hose length wise and slip it over the a/c lines. Use worm clamps to hold 'em tight against the a/c lines.
You can get some at http://www.mcmaster.com/
http://www.mcmaster.com/ctlg/D...etAct=
"Silicone Rubber Heater Hose
• Tube: Orange silicone elastomer
• Cover: Blue silicone elastomer
• Reinforcement: Nylon fiber
• Temperature Range: -65° to +350° F
Handles low-pressure service for most heating applications, and resists coolant additives. Meets SAE J20R3, Class A standard for heater hose. Full coil length is 50 ft. Please order in 5-ft. increments "
Hope that helps
Hope that helps
