Looking for OEM Honda TB sizes...
B16, B18A are 58mm. I believe the B18C (JDM ITR) and B18C5 are 62mm. The B18C1 (USDM GSR) is 58mm as well (pretty sure). D and H series I have no idea. I think the D's are around 55mm? The H's should be near the same size as the B's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R »</TD></TR><TR><TD CLASS="quote">B16, B18A are 58mm. I believe the B18C (JDM ITR) and B18C5 are 62mm. The B18C1 (USDM GSR) is 58mm as well (pretty sure). D and H series I have no idea. I think the D's are around 55mm? The H's should be near the same size as the B's.</TD></TR></TABLE>
I don't know about the others but I agree, b18c1 is 58mm and b18c5 is 62mm.
i believe the B18b, b18c, newer b16s and H22/3 have 60mm, type r and type s are 62, and old b16 and b18a are around 58-59. Not to sure about Dseries somewhere around 55. These numbers are at the TB plate
Modified by MrMike at 12:11 AM 9/10/2004
Not one post that was right.
d series 56 except dohc zc/a6 which are 55
b series 90-93 b18a first gen b16 58 mm
all 94+ b series 60 mm also 92-93 b16a
accord 56 mm
prelude 92+ dohc 60 mm
itr 62 mm
s2000 62 mm
Wow working on Hondas and checking specs works. Maybe some of you guys should try it sometime
accord 56 mm
itr 62 mm
s2000 62 mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">h23/22 = 60mm, positive on this
d16 is a 58mm i think?</TD></TR></TABLE>
I thought the H22 Tb was 62mm like the ITR b/c ppl used to use those instead b/c they are cheaper than the ITR!
I may be wrong but I think the H22 is 62mm!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">
I may be wrong but I think the H22 is 62mm!</TD></TR></TABLE>
Thats exactly what i though... 92-96 H22A TB's are 62mm, H22A4 97+ TB's are 60mm???
The ITR and 92-96 H22A bore capacity is the same as well...
All jdm h22 lude motors I have messed with have had 60 mm. The actual material on the throttle body maybe enough to bore to the same specs has a bored itr tb but there 60 mm stock. Micrometer can come in handy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alld16a »</TD></TR><TR><TD CLASS="quote">All jdm h22 lude motors I have messed with have had 60 mm. The actual material on the throttle body maybe enough to bore to the same specs has a bored itr tb but there 60 mm stock. Micrometer can come in handy</TD></TR></TABLE>
Micrometers dont lie! Good job!
Jflex
17
Apr 14, 2004 11:45 AM
