Short shifter Q's
Old Sep 9, 2004 | 12:50 PM
Oz's Avatar
Oz
Default Short shifter Q's
I notice that my Skunk2 shifter has ball bearings in it, unfortunately the guy before me apperently bought the wrong one and it sits on my exhaust. It seizes for a few seconds when I drive through water because it gets so hot. I want to buy a B&M and I notice that it doesn't have ball bearings. Any one know if this is bad? I keep seeing that people like the B&M shifter but I am reluctant. Any ideas?
Old Sep 9, 2004 | 01:33 PM
93GSRB17's Avatar
Default Re: Short shifter Q's (Oz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oz &raquo;</TD></TR><TR><TD CLASS="quote">I notice that my Skunk2 shifter has ball bearings in it, unfortunately the guy before me apperently bought the wrong one and it sits on my exhaust. It seizes for a few seconds when I drive through water because it gets so hot. I want to buy a B&M and I notice that it doesn't have ball bearings. Any one know if this is bad? I keep seeing that people like the B&M shifter but I am reluctant. Any ideas?</TD></TR></TABLE>
I have the same type of problem with my Solo Short shifter everytime it rains. I think i have my problem because i had to remove the shield because it kept getting in the way of one of my gears.
Old Sep 9, 2004 | 01:38 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Never had problems with my shifter seizing, it has sealed bearings in the bottom also, and the pipe has no heat shields, either.
I highly recommend you use a shifter w/ sealed bearings in the bottom. With the B&M you have to transfer the o-rings and junk from the stock shifter over to the B&M, which leaves some of the stock shifter's sloppy feeling left in the shifter, even with poly bushings. Also with sealed bearings and proper spacers, shifter movement will always be smooth, no matter how tight the bolt is.
Old Sep 9, 2004 | 04:49 PM
NOahFATCHICS's Avatar
Default Re: Short shifter Q's (93GSRB17)
i have the B&M short shifter...im not really too impressed with it...raddels on the high way...very tight feel...always have problems shifting into 2nd during a race...and its not my tranny...
might just be my driving...
Old Sep 10, 2004 | 07:48 AM
Community Builder
Default Re: Short shifter Q's (NOahFATCHICS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOahFATCHICS &raquo;</TD></TR><TR><TD CLASS="quote">i have the B&M short shifter...im not really too impressed with it...raddels on the high way...very tight feel...always have problems shifting into 2nd during a race...and its not my tranny...
might just be my driving... </TD></TR></TABLE>
You may have tightened the bolt too much. As I said, if you have a shifter w/ bearings and spacers, the shifter will still move the same no matter how tight the bolt is.
Old Sep 10, 2004 | 10:15 AM
Oz's Avatar
Oz
I have been looking for the shield online but can't find it. I want to try it but is it called something else?
Old Sep 10, 2004 | 10:38 AM
xprohx's Avatar
I think too much
I have no problems with my skunk2 shifter. It use to hit the exhuast when I go to second, but during the hi flow cat install, the exhaust was hung down a little lower. Now it feels like stock with a shorter throw.
DeleriousZ
Transmission & Drivetrain
Dec 6, 2012 07:13 PM
hectic57
Feb 27, 2008 08:16 PM
vlc92189
Sep 14, 2007 06:13 AM
snouka
May 5, 2006 11:22 AM
hialeahzbg
12
Aug 10, 2005 09:13 PM
