Replacing Alternator HELP!!! ASAP!!!
Old Sep 9, 2004 | 10:06 AM
90 Si Hatch's Avatar
Default Replacing Alternator HELP!!! ASAP!!!
i have to replace my alternator on my 90 Civic Si and i was wanting to know if you have to take out the driver side axel, i have been told i need to but i wasn't sure and if there is anything else i need to know please let me know if some one could get back toi me befoure 5 PM today. Thanks Isaac
Old Sep 9, 2004 | 10:08 AM
crxgator's Avatar
Default Re: Replacing Alternator HELP!!! ASAP!!! (White90SiHatch)
no you dont have to take out your axle...just take out the lower alternator bracket and the alternator comes right out...
Old Sep 9, 2004 | 10:12 AM
unltdacc12's Avatar
if you want you can remove it from the top. all you have to do is remove the mc from the booster (do not remove the brake lines) and push it to the side. I found this way to be the easiest.
Old Sep 9, 2004 | 10:37 AM
shawn_crx's Avatar
Default Re: Replacing Alternator HELP!!! ASAP!!! (unltdacc12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unltdacc12 &raquo;</TD></TR><TR><TD CLASS="quote">if you want you can remove it from the top. all you have to do is remove the mc from the booster (do not remove the brake lines) and push it to the side. I found this way to be the easiest.</TD></TR></TABLE>
Old Sep 9, 2004 | 10:50 AM
viper_2_4's Avatar
when I do it, I just take off the braket that holds it on and slide it through the wheel well.....no need to take out axle
Old Sep 9, 2004 | 12:18 PM
4drEF's Avatar
Keyboard Humorist
You can also pass the alternator under the intake manifold to the passanger side of the car.
Then you can lift it up and out.
Old Sep 9, 2004 | 01:24 PM
CRXRTYPE's Avatar
Default Re: Replacing Alternator HELP!!! ASAP!!! (4drEF)
easiest way is to slide the alternator under the intake manifold, and squeeze it
threw the two coolant hoses side by side, saves a lot of headaches
Old Sep 9, 2004 | 02:08 PM
hatchinprogress's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">You can also pass the alternator under the intake manifold to the passanger side of the car.
Then you can lift it up and out.</TD></TR></TABLE> i 2nd that
Old Sep 9, 2004 | 02:23 PM
D15Bbigred's Avatar
GET'ER DONE!!!!!!
Old Sep 10, 2004 | 03:48 AM
Default Re: (MaxPowerZC)
well i GOTER DONE!!! last night i got it out. but the easyest way for me to do it was to take out the Axel i just jacked it up real high on one side and pulled the axel out. but then when i got the old Alternator out i couldn't get the new one back in so i had to take out the oil filter out to get the new one in. but it wasn't to bad only took me about 2 hours doing everything so i'm happy!!. so Thanks to every one that gave me their point of views
djrico724
Aug 10, 2008 09:42 PM
Nick7
Oct 25, 2005 11:17 PM
dc2go
Sep 20, 2005 11:10 AM
kaotikcrx05
Jan 27, 2005 10:11 AM
CivicHB89
Dec 14, 2004 08:05 PM
