cutting out under boost
I am have a slight problem I have had my turbo on for about 4 months now and just last week it started cutting out under boost and doesn't feel like my v-tec is working i have checked all the conections and grounds and pulled the codes off the ecu. Its like it has a rev- limiter at 7200 now and cuts in and out until that point, but then once in awhile it runs like a raped ape
anyone help or having the same problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeesB »</TD></TR><TR><TD CLASS="quote">I am have a slight problem I have had my turbo on for about 4 months now and just last week it started cutting out under boost and doesn't feel like my v-tec is working i have checked all the conections and grounds and pulled the codes off the ecu. Its like it has a rev- limiter at 7200 now and cuts in and out until that point, but then once in awhile it runs like a raped ape
anyone help or having the same problem?</TD></TR></TABLE>
Have you checked your oil pressure? Remember VTEC relies on good oil pressure. A buddy of mine has a stock GsR integra 4dr...and he was running low on oil...it would feel like VTEC wouldn't even ingage. That would be my first bet on trying to resolve your problem.
well to date i have check the oil the v-tec soliod pressure switch all connections
all grounds engine codes ect ect and still nothing even checked the timing just in case
my gap is at 28 also and i changed plugs wires and tested my coil what next
i guess maybe a break in my v-tec wire???????? I dont know where else to turn
my vafc says its hitting v-tec but i know its not
pretty messed up isnt it
well on the newest update still nothing have changed everything poss v-tec solinoid (sp?) pressure switch ecu hooked a gauge to my oi pressure could it be the v-afc?????
please help
please help
