Need to pass inspection,please help NOx failed
Old Sep 9, 2004 | 03:09 AM
BoRiCuA's Avatar
Default Need to pass inspection,please help NOx failed
Guys after the swap in my crx, d16z6 went for vehicle inspection and i failed for emissions,(NOx standard 1304,reading 3292 result fail) please help how can i fix this. thanks
Old Sep 9, 2004 | 03:33 AM
dc5r2002's Avatar
Default Re: Need to pass inspection,please help NOx failed (BoRiCuA)
do you have the stock cat on there?
Old Sep 9, 2004 | 08:42 AM
rev-speed's Avatar
post ur smog papers
we dont have crystal ***** here
Old Sep 9, 2004 | 08:58 AM
Jokerluv's Avatar
Default Re: Need to pass inspection,please help NOx failed (4cylinder)
use a pint of isopopyl alcohol its works believe me
Old Sep 9, 2004 | 01:57 PM
BoRiCuA's Avatar
Default Re: Need to pass inspection,please help NOx failed (Jokerluv)
I have the stock cat converter on their, i don't use cheap gas 93+2 octane and my smog results are as stated above, it's the only thing i failed for? some of the certified technicians at my job said it could be timing, what do you guys think?
Old Sep 9, 2004 | 02:32 PM
non-VTEC's Avatar
it can be timing.......but what were the other readings?
limits and results for HC and CO?
Old Sep 9, 2004 | 09:38 PM
rev-speed's Avatar
a smog tech. is alot different from a reg tech.
and a full report will tell alot
all of the 4 gas affect each other
by the way did u even watch while the guy smog ur car?
did they even check ur ignition timing?
did they smog ur car in second gear even if ur at 3k rpm?
like i said ur smog sheet will tell alot.
Old Sep 9, 2004 | 10:01 PM
92bubblesi's Avatar
I was having a hard time passing DEQ (Department of Environmental Quality) here in Oregon because I was failing on Hydocrabons. To beat Hydrocorbons I would lean out the mixture via a Ajd Fuel preesure regulator. If I went to far I would pass hydro carbons but would fial NOx. NOX can be caused by hot cylinder temps, i.e. running too lean or advancing ignitiion timting to far.
Make sure you are running a proper mixture and try retarding your timing a bit.
slayersluck
Engine Management and Tuning
Mar 6, 2009 04:32 PM
Cloneufc
Oct 24, 2008 04:28 PM
zipoton
13
Jan 16, 2008 06:26 AM
Steve91
Jul 29, 2002 07:59 PM
