Not Starting after Turbo Installed
Old Sep 8, 2004 | 09:46 PM
Endoe's Avatar
Default Not Starting after Turbo Installed
I have a 00 B18B1...ive just installed the turbo on it today..after i finish all the installation the engine will not crank over...any ideas of what might of cause it to not carnk over....or some common turbo mistake that can happen...
Old Sep 8, 2004 | 10:27 PM
beepy's Avatar
Default Re: Not Starting after Turbo Installed (Endoe)
Nothing to do with the turbo, but rather something you forgot to put back together.
Old Sep 9, 2004 | 01:42 AM
JDM_Risa's Avatar
Default Re: Not Starting after Turbo Installed (beepy)
maybe battery dead since you were prolly playing music durings installation just an assumption....just playing.......it shouldn't be anyhting related to the turbo.....
check for blown fuses and what not loose starter connectors
Old Sep 9, 2004 | 06:16 AM
Endoe's Avatar
Default Re: Not Starting after Turbo Installed (GunMETAL_TEgRa)
all the fuses are ok...could we have a fuel problem?
Old Sep 9, 2004 | 06:22 AM
underpressure02's Avatar
Did you check the volatage on the battery? Did you make sure the connectors are on tight and that you did not undo the ground for the battery. Is the car turning over at all and just not starting?
If it is not cranking over then start with the basics. Check that or reply if all that is good.
Did you pull a plug and ground it out to see if you are getting spark?
Old Sep 9, 2004 | 11:18 PM
Endoe's Avatar
Default Re: Not Starting after Turbo Installed (underpressure02)
check all plugs and relays...getting sparks...hear fuel pump go on...battery is good, tried it on a van and it started right up...it has grounds.... im thinking it might be the fuel pump or fuel filter...im gonna try putting the stock fuel line back on...well see from there..
Old Sep 9, 2004 | 11:24 PM
Mase's Avatar
plug wires on correctly?
Old Sep 10, 2004 | 08:51 PM
Endoe's Avatar
Default Re: Not Starting after Turbo Installed (Mase)
Installed the fuel pump backward.....engine cranks over... but now fuel pump is making weird noises..like it is struggling or something....
Big_Mike
Mar 22, 2004 11:26 PM
