combustion chamber
Old Sep 8, 2004 | 09:08 PM
ildknyli's Avatar
Default combustion chamber
I was wondering, if I increase the bore size on a GSR block to 84mm would I also have to increase the size of the combustion chambers on a b16a head to accomindate the increased bore size of the block?
Old Sep 8, 2004 | 09:40 PM
flow-zilla's Avatar
Default Re: combustion chamber (ildknyli)
some people do but i wouldnt suggest it because the piston that your planning on using is designed to work with the stock chamber dimensions ,but then again is this turbo or all motor ?? if its turbo then it is suggested if all mmotor no unless you have pistons made specifically for that ...
Old Sep 9, 2004 | 07:08 PM
ildknyli's Avatar
Default Re: combustion chamber (flow-zilla)
Its for turbo. Who makes turbo pistons designed to work with stock chamber dimentions?
Old Sep 9, 2004 | 10:23 PM
rev-speed's Avatar
everyone that makes 84mm pistons
dritan
Jan 7, 2011 07:18 AM
hYbRid_Eg6
Mar 16, 2010 07:40 AM
EL TYPE R
Jul 15, 2009 01:24 PM
Jap_Spec_Imports
Jan 23, 2008 07:34 AM
