itr cams on b16???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">I thought ITR/CTR cams are not good for f/i application.
I heard GSR cams is better for turbo too.</TD></TR></TABLE>
GSR cams in the stock location are better however, Cam gears and ITR/CTRs will provide much more both N/A and Boosted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h0tsihatch »</TD></TR><TR><TD CLASS="quote">i would also like to know how much of a power difference it would be??</TD></TR></TABLE>
Depends on your engine. Noticable, anywhere from 5-12 whp in the powerband.
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
wrong the overlap on the ctr itr combo is too big for turbo applications. we have found that stock gsr cams work the best for turbo. and to answer the other question when changing from b16a cams to ctr you can expect an increase some where around 10hp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS »</TD></TR><TR><TD CLASS="quote">wrong the overlap on the ctr itr combo is too big for turbo applications. we have found that stock gsr cams work the best for turbo. and to answer the other question when changing from b16a cams to ctr you can expect an increase some where around 10hp</TD></TR></TABLE>
READ YOU FOOL. With cam gears!
