Camshafts for b17
What's the best camshafts for a b17 with bolt-ons? On a 500-600 dollar buget so for sure i'm going to have to get some used ones. What should I be looking for?
Depending on the motor set up, CTR/ITR would be a great. For alittle bit more Skunk2 Stage 1 or even the Buddy Club III. Yu might want to get some sort of VTEC - FUEL controler
Good Luck
Good Luck
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
get a ctr intake and itr exhaust because the ctr's are generally more expensive but the ctr intake cam is slightly more aggressive and the exhaust cams are the same
On a $500-$600 budget, about all you are going to get is CTR/ITR, Comp/ZEX, or Crane. CTR/ITR works. But gains are somewhat limited. On the other hand, Comp/ZEX and Crane are both unproven. Also, this cost does not take into account a spring upgrade, which will cost a couple of hundred dollars more.
don't skimp on valvetrain(springs+retainers) even if it means saving for the ctr/itr's, you can just run the itr valvetrain on most stage 1 cams like skunks, and it sounds like maybe on the buddy clubs but ive never really looked at em so someone is gonna have to back me up
