need advice: popping noises from intake filter at idle
Old Sep 8, 2004 | 01:51 PM
Cowboy's Avatar
Default need advice: popping noises from intake filter at idle
does anyone know how to correct it? i've heard that it could be back fire in the intake manifold and the engine is too advanced during idle, so i retarded it...but it's still there.
the popping noise is more prominent when naturally aspirated or turbo charged....but less noticable when supercharged....so i think it might be something to do with the intake manifold side???
any thoughts?
Old Sep 9, 2004 | 12:34 PM
Cowboy's Avatar
bump
Old Sep 9, 2004 | 12:55 PM
91civicEX's Avatar
Default Re: need advice: popping noises from intake filter at idle (Cowboy)
im supercharged and i didnt hear any popping noises from my intake when i was NA or right now either. how loud is it? do u hafta put ur ear on the intake manifold?
Old Sep 9, 2004 | 02:30 PM
Cowboy's Avatar
with the supercharger, you would have to put your ear to the filter to hear it
but with the turbo or N/A, you can just stand next to the car with the hood down, and you'll hear it
Old Sep 9, 2004 | 05:58 PM
bonestockls's Avatar
Default Re: (Cowboy)
do a compression test or cylinder leakage test....
Old Sep 10, 2004 | 02:10 PM
Cowboy's Avatar
Default Re: (bonestockls)
hmmm......i'm not totally ruling out that something might be wrong with my engine.....but i know 3 other people with the same problem, and one of them has a rebuilt engine
any other ideas?
Old Sep 10, 2004 | 03:07 PM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cowboy &raquo;</TD></TR><TR><TD CLASS="quote">hmmm......i'm not totally ruling out that something might be wrong with my engine.....but i know 3 other people with the same problem, and one of them has a rebuilt engine
any other ideas?</TD></TR></TABLE>
its the ECU, so it is somehow related to fuel and/or timing control from the ECU.
Old Sep 10, 2004 | 03:31 PM
Default Re: (Black-LS)
yep , as the previous poster stated , I definitively diagnose you problem over the internet, it is without exception the ecu....
Old Sep 10, 2004 | 05:47 PM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonestockls &raquo;</TD></TR><TR><TD CLASS="quote">yep , as the previous poster stated , I definitively diagnose you problem over the internet, it is without exception the ecu.... </TD></TR></TABLE>
I am one of those 3 people he was refering to. All of us had the same aftermarket standalone ECU. The original poster failed to mention that point of his setup.
Old Sep 10, 2004 | 11:22 PM
The-LS's Avatar
this is why I say its the ECU, same thing going on as you. Standalone ECU that I'm presuming its untuned properly.
https://honda-tech.com/zerothread?id=775753
and just for reference https://honda-tech.com/zerothread?id=820869
Old Sep 12, 2004 | 06:47 PM
Default Re: need advice: popping noises from intake filter at idle (Black-LS)
right on, extra information is always good
Old Jul 19, 2011 | 11:11 PM
Lerlo's Avatar
Hi, was wondering if the original poster solved the problem.
I have the EXACT same problem.
Im runnign a fully rebuilt, recon b20vtec.
Im running powerfc.
It popped from day 1, only on idle, 10-30 seconds apart.
It makes good power, but its annoying the hell outta me.
I changed Cam gears, changed cam timing, ignition timing, a/f ratio, injectors, throttle body. I opened up the intake manifold and there was NO CARBON build up on valves.
Im on the verge of selling the car away noW!!!
Could it be the powerfc?
Old Jul 20, 2011 | 06:41 PM
Lerlo's Avatar
Im running powerfc.
Bump
RO_SUNNY
K Series
Oct 29, 2016 03:58 AM
BIGef
13
Oct 27, 2012 12:25 PM
ph0en1x
Nov 10, 2010 10:20 AM
aznxpyroboi
Jul 21, 2007 09:06 AM
NoRthstaR_
Nov 17, 2006 04:35 PM
