Help!!! Hydrolocked!
Old Sep 8, 2004 | 04:43 AM
hwoody77's Avatar
Default Help!!! Hydrolocked! Updated!! Help!1
Well here's what happened, I kept the CAI on because I was going to use it for intercooler piping for my turbo kit...
So I manage to start the car and its riding really rough so I drive it real slow for about 10 miles to the shop.
I remove the spark plug cover and the plugs...no water...take out the TB practically any water, so I just got an oil change and have driven the car...no problem.
I did a compression test...
Cylinder 1,2, and 3 were at around 230, cylinder 4 was at 180....is that need to worry?
Also, at first I was hearing a loud clicking sound...really LOUD, like valves tapping, but it has died down...what could that be?
Someone told me I might have some bent-rods, but wouldn't my car run like garbage?
As of right now, I give a very slight tapping sound, and the idle is a little rough, but the car drives fine...anyone know what could be the problem?
Modified by hwoody77 at 3:36 AM 9/9/2004
Old Sep 8, 2004 | 04:51 AM
snatch's Avatar
Default Re: Help!!! Hydrolocked! (hwoody77)
I think you can pull the spark plugs and see if there is water in the cylinders.
Old Sep 8, 2004 | 08:25 AM
EK22snatch
Guest
Posts: n/a
Default Re: Help!!! Hydrolocked! (******)
oh man, thats not good... youre probably gonna wanna just go ahead and heat your engine up with a heating gun to boil out the water
naw, but seriously though, you can turn a good engine over by hand. just grab a pully, use a ratchet on a pully nut or whatever... it sounds electric, if you hydro lock an engine its instant... not problems later on occuring
Old Sep 8, 2004 | 10:37 AM
Supernatural's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hwoody77 &raquo;</TD></TR><TR><TD CLASS="quote">I was driving to school today and hit a big puddle...
the car cranks, and starts real fast but then turns off...
Do you think I'll be ok?
Help, what do I do!!</TD></TR></TABLE>
take your plugs out and crank the motor, squeeze whatever water is left ....
but if the car starts and then dies out .........do a compression check
the valves seem like the may be damaged...
DoHcZC91si
Aug 31, 2008 09:34 PM
wastedyouth2542
Aug 27, 2008 01:04 PM
Speed_1
May 30, 2008 08:28 AM
radeonboy
67
Oct 25, 2007 02:46 PM
