really quick questions before i start...
Old Sep 8, 2004 | 03:31 AM
b18c_ek's Avatar
Default really quick questions before i start...
alright guys i have a few questions before i start these projects..
1. i have a blown gsr block and i was going to put in a LS crank and LS rods, what pistons can i use? what will be needed to fit the crank in the block correctly?... do i need to machine anything? will i still be able to use the oil squitters, heard it gets in the way but is there any way around it? how about the gsr block girdle? can i use that?
2. i also have a b20 block and want to put a vtec head on. i just wanted to know if the pr3 pistons will fit properly, if it does, i see that compression is like 11.9, is that too high on stock b20 sleeves? what rods can i use? how is the piston to head clearance?
Modified by b18c_ek at 4:47 AM 9/8/2004
Old Sep 8, 2004 | 09:02 AM
GOLDBERG's Avatar
Default Re: really quick questions before i start... (b18c_ek)
the pr3's are 81mm...your b20 is 84mm so no it wont fit..
as fr the ls stuff..search
jdragon1974
20
Aug 7, 2014 12:29 PM
ghosthatch
Oct 4, 2010 12:08 AM
yoRt
Dec 3, 2008 05:08 PM
b16 pwrd ek
Nov 23, 2004 06:46 AM
