SOMEONE HELP ME!!!
Old Sep 7, 2004 | 08:14 PM
JhorickJFL's Avatar
Default SOMEONE HELP ME!!!
the setup:
EF 4 DOOR LSVTEC
ITR PISTONS
ITR CAMS
PR3 ECU (mugen chipped)
okay i'll describe the problem:
after driving it for maybe 5 min, the motor seems to struggle to stay alive. i tried driving it but when i push the gas, it's like it doesn't respond. i turned it off, then i reved it a bit, then as soon as it idel's it again struggles to stay alive. going into first is when it's really going to die, but when i leave it in neutral it's just reving so low and seems like when i push the gas it barely responds. it barely even reved.
anyone help me out. i gotta fix this problem
pics would be great. thanks
-john
Old Sep 7, 2004 | 08:15 PM
Rostr02's Avatar
Default Re: SOMEONE HELP ME!!! (JhorickJFL)
when is the last time u changed ur fuel filter?
Old Sep 7, 2004 | 08:17 PM
slate13530's Avatar
Sounds like your Catalytic is clogged.
Old Sep 7, 2004 | 08:19 PM
JhorickJFL's Avatar
Default Re: SOMEONE HELP ME!!! (slate13530)
Rostr02 : it's new
slate13530 : i'm open header right now, i still need to line up the exhaust
Modified by JhorickJFL at 5:31 AM 9/8/2004
Old Sep 7, 2004 | 09:16 PM
speeddave's Avatar
maybe clogged injectors? i had a similar problem w/my ls/vtec, and the injectors were no good. but i'd go through the basics, try to isolate what might be causing that, are you over/under fueling? timing off? wiring cross'd up? cap/rotor/plugs(gapped correctly?) etc... eliminate what you know and go from there.hth
Old Sep 7, 2004 | 10:50 PM
fed's Avatar
fed
your timeing is off a tooth
Old Sep 7, 2004 | 10:57 PM
B16 CRX's Avatar
Default Re: SOMEONE HELP ME!!! (fed)
Check your compression
Old Sep 8, 2004 | 04:57 PM
JhorickJFL's Avatar
Default fackkkkkkkkkkk
now as i press the gas it goes the opposite. it rev's DOWN not up. i'm currently just leaving it in the garage and try reving it, to see what really happens. we tried a pw0 ecu and no diff, no codes, same everything
Old Sep 8, 2004 | 06:42 PM
onePOINTsix's Avatar
Default Re: fackkkkkkkkkkk (JhorickJFL)
MPFI swap? sounds like you didnt swap the outside 2 wires on the TPS
Old Sep 12, 2004 | 12:23 AM
JhorickJFL's Avatar
still the same problem,
press the gas it revs downwards then dies
idle it's okay
ACrite3404
Mar 25, 2008 04:29 PM
alex_s817
Mar 6, 2007 05:38 PM
b20vtecv8killer
Jun 26, 2004 06:04 PM
Type RS
Jan 26, 2004 05:09 PM
typevimports
Feb 27, 2002 07:18 AM
