Weird Noise When Clutch Is Pushed In
Old Sep 7, 2004 | 07:01 PM
asubennett's Avatar
Default Weird Noise When Clutch Is Pushed In
Low RPM shifting- under 5000rpm say- it makes ZERO noise
High RPM shifting- Above 5500 75% or more throttle- When the clutch is pressed in to shift into the next gear it makes a strange squealing noise.
IF the clutch was bad wouldn't it squeal when the clutch is engaged on the flywheel, I.E. clutch pedal out??
Any Help would be appreciated.
Old Sep 7, 2004 | 08:55 PM
asubennett's Avatar
Default Re: Weird Noise When Clutch Is Pushed In (asubennett)
Up for some help.
Old Sep 8, 2004 | 12:20 AM
_Endless_'s Avatar
i had a similar experience with my 1st car(not a honda) only that it squeals in all rpm range. the problem was the release bearing so i had it replaced together with the pressure plate.
Old Sep 8, 2004 | 06:52 AM
asubennett's Avatar
Default Re: Weird Noise When Clutch Is Pushed In (_Endless_)
Cool, thanks for the heads up. Any more advice.
victor.m
Apr 4, 2009 09:19 PM
Dwalker
Jan 11, 2008 12:45 PM
J-Willz
Honda Civic (2001 - 2005)
Jul 24, 2007 08:24 PM
Tokyo_X-treme_Racer
18
Jan 28, 2004 11:48 AM
