clutch release noise? help
Re: (Tokyo_X-treme_Racer)
It could be the throwout bearing wearing out and may need replacement. While your at it you might as well replace the clutch pressure plate and clutch discs as well.
Re: (Spartanic)
Holy trying to get this guy to spend his money, Batman! You say noise from your clutch, but I'm assuming you mean clutch pedal. And you say after you release it. Did you mean when you're releasing it? If it's just the clutch pedal, it's nothing to worry about. It's just a spring doing it's work. If I assumed incorrectly, I apologize.
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Is it like a squeak or stiffness when you press/release the clutch? or is it a clicking noise when the clutch is let up?</TD></TR></TABLE>
Yes thats it, what you said. Car still drives normally, just that the sqeaky noise just all of a sudden began after a few days ago.
1 Post
It could either just be a squeaky pedal or you need to take the boot off of the clutch slave cylinder and grease up where it touches the fork. Id bet on the second.
Re: (JRI94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 »</TD></TR><TR><TD CLASS="quote">Holy trying to get this guy to spend his money, Batman! You say noise from your clutch, but I'm assuming you mean clutch pedal. And you say after you release it. Did you mean when you're releasing it? If it's just the clutch pedal, it's nothing to worry about. It's just a spring doing it's work. If I assumed incorrectly, I apologize.</TD></TR></TABLE>
Yes, it's after I release the clutch pedal.
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tokyo_X-treme_Racer »</TD></TR><TR><TD CLASS="quote">
Yes, it's after I release the clutch pedal.</TD></TR></TABLE>
What kind of noise is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx »</TD></TR><TR><TD CLASS="quote">whenever i press my cluth in all the way it makes a sqeaky noise also..but it has been like this for 1 year now</TD></TR></TABLE>
This is normal. Dont worry about it.
Re: (BauleyCivic)
This is normal. Dont worry about it.</TD></TR></TABLE>
cool.. just wondering do u know what it is making that noise bauley?
Re: (Vtecin94dx)
So you've never had a problems with taht squeak noise?
Risky Business
Re: (Vtecin94dx)
cool.. just wondering do u know what it is making that noise bauley?</TD></TR></TABLE>
Its the spring for the clutch pedal...I took mine to the honda dealer...they said nothing was wrong but lubed it up anyway...still makes the noise when its cold out sometimes...but its fine
Re: (BauleyCivic)
Its the spring for the clutch pedal...I took mine to the honda dealer...they said nothing was wrong but lubed it up anyway...still makes the noise when its cold out sometimes...but its fine </TD></TR></TABLE>
Where I live it has been raining and quite chilli. Maybe I just have to lube mine up.
Re: clutch release noise? help (Tokyo_X-treme_Racer)
The clutch pedal on every singal Honda I have owned has done that.
No worries, just the spring from what I can tell, although on my 00 Si I did get a free CC out of it!!!
Risky Business
Where I live it has been raining and quite chilli. Maybe I just have to lube mine up.</TD></TR></TABLE>
Yeah if your problem is just a squeak when you press in or release the pedal dont worry about it
Re: (BauleyCivic)
allright cool thanx bauley like always
JamesV
12-01-2005 06:35 AM
