What is a p30 ac bracket from?
Old Sep 7, 2004 | 06:21 PM
bullock's Avatar
Default What is a p30 ac bracket from?
I have a b16 swap in my 94 civic and i purchased an ac bracket from ebay that says (J P30) on the side. The guy said it was from an obd1 sir from japan. I thought it was the part i needed for my ac compressor but the compressor bolts do not line up. I was under the impression that i could use my sohc compressor on the b16. Do I need the ac compressor off a jdm sir to make this bracket fit and would that ac compressor's lines match up with mine or will this part not fit at all? Any help would be appreciated?
Old Sep 7, 2004 | 06:25 PM
b18cls1's Avatar
Default Re: What is a p30 ac bracket from? (bullock)
p30 bracket is a delsol b16 bracket and you need a delsol a/c compressor or 99si
Old Sep 7, 2004 | 07:02 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cls1 &raquo;</TD></TR><TR><TD CLASS="quote">p30 bracket is a delsol b16 bracket and you need a delsol a/c compressor or 99si</TD></TR></TABLE>
wropng. a p54 is the del sol b16. thats what you need.and youi keep your civic compressor
Old Sep 7, 2004 | 07:05 PM
bullock's Avatar
Default Re: What is a p30 ac bracket from? (hybridvteceg)
the p30 came from a jdm eg so you would figure it would use the same ac compressor as a usdm sohc. So can i use the p30 with a dohc compressor or will i need a p54
Old Sep 7, 2004 | 07:08 PM
dfoxengr's Avatar
i would think that the japanese compressor would be just like our DOHC since its the same motor in there
Old Sep 7, 2004 | 07:09 PM
dfoxengr's Avatar
but you need the p54 for this combo of parts:
92-95 civic
sohc compressor
Bseries motor.
Old Sep 7, 2004 | 07:13 PM
bullock's Avatar
see the p30 came from an eg with a b16 from japan so it has to work somehow.I think it should be the same as p54 just from japan
Old Sep 7, 2004 | 07:43 PM
dfoxengr's Avatar
whatever you think chief, but of it doesnt line up with your civic comp. which you said it doesnt. then its not the same.
Old Sep 7, 2004 | 07:50 PM
beaterdriver's Avatar
it sounds like the same mount that came in the 99-00si's. from japan or not, it prob the same part number or pretty daym close to it
Old Sep 8, 2004 | 08:37 PM
bullock's Avatar
Default Re: (beaterdriver)
today i installed the bracket and it fit just like a p54 would, It has the side mount and the tension pulley lines up with crank pulley. My sohc compressor does not line up with this p30, I know,so then the jdm sir must have had a dohc compressor, so could i just use a dohc compressor and would all the ac lines line up?I know the sohc and dohc compressors only have one wire running to them already.
Old Sep 8, 2004 | 08:48 PM
dfoxengr's Avatar
Default Re: (bullock)
thats what i told you in the first place. cause it IS a dual cam motor. just get the p54...
Old Sep 12, 2004 | 07:05 PM
bullock's Avatar
Default Re: (hybridvteceg)
know someone who has one?
Old Sep 12, 2004 | 07:09 PM
dfoxengr's Avatar
hondaautomotiveparts
Mrevann
May 19, 2011 01:02 PM
Chrisrey86
May 6, 2007 09:16 PM
EJ8VTEC
May 25, 2005 06:23 PM
EJ8VTEC
May 23, 2005 08:06 PM
davken1102
Mar 18, 2004 09:52 PM
