Whats the best engine swap to do for a 2dr 90 accord??
Old Sep 7, 2004 | 06:02 PM
BlazeTeck2000's Avatar
Default Whats the best engine swap to do for a 2dr 90 accord??
i want to change the engine in my car it has 490,780 miles and still going stong but i want to put a engine that its easy to do that wont cost as much as a h22 swap ....
Old Sep 7, 2004 | 06:32 PM
FatJoe's Avatar
Default Re: Whats the best engine swap to do for a 2dr 90 accord?? (BlazeTeck2000)
h23
Old Sep 7, 2004 | 06:52 PM
v4lu3s's Avatar
RTFM
buick v6
Old Sep 7, 2004 | 08:29 PM
n-line4's Avatar
It's called another F22.... but don't waste your time and get a stinkin H22 already.
Old Sep 7, 2004 | 09:18 PM
rhaccord's Avatar
Default Re: (n-line4)
Holy F*ck, 490, 000?!? thats crazy. I have a 91 accord and swapped an h22 with 61k original miles on my f22, its still sitting in my garage.
Old Sep 7, 2004 | 09:58 PM
H2290's Avatar
Default Re: (rhaccord)
Your money, your final goal, and your current engine's condition dictate what you should do.
H23 is good for boost, do you want boost?
F22 is really good for boost if it is in good condition.
H22 is okay for boost in comparison to the other two but great for N/A in comparison.
Do a lot of research and find out the advantages and disadvantages of each.
Old Sep 7, 2004 | 11:18 PM
DIYaccord's Avatar
Default Re: (H2290)
f18b
Old Sep 8, 2004 | 07:59 AM
alb_accord's Avatar
if i go for a swap just go with the h22. u gona love it. lol u can do the work ur self with our help too. lol
Old Sep 8, 2004 | 08:37 AM
TOAB's Avatar
unless you want to make it fast... jdm dohc f22b. cheap motor. 160hp. basically an h23 but a weeeeeee bit smaller with sturdy F guts.
Old Sep 8, 2004 | 08:44 AM
Default Re: Whats the best engine swap to do for a 2dr 90 accord?? (TOAB)
but is the f22b easy to put on ?
Old Sep 8, 2004 | 08:47 AM
TOAB's Avatar
just as easy as an h23 if not easier i would assume.
Old Sep 10, 2004 | 09:05 PM
Default Re: (TOAB)
whats thediffrence on h22 and h23
anyone everheard of a honda odassy engine in a 91 se accord?
Old Sep 10, 2004 | 09:59 PM
95ACEX's Avatar
Default Re: (BlazeTeck2000)
I'm pretty sure the oddyssey uses the J30 from the v6 accords...I may be mistaken though. It definitely wouldn't bolt up and even if you could get it to fit it would be more of a PITA than it would be worth.
Old Sep 11, 2004 | 08:09 AM
FatJoe's Avatar
Default Re: (95ACEX)
actually the oddyssey used the f series I4... same as the accord. so it would be a pretty EASY and WORTHLESS swap. i believe the f22a6 is its engine of choice.
EDIT: accordinglydone.com says the 95-97's used the f22b6... but it doesnt say anything about newer ones...so who knows?
Old Sep 11, 2004 | 08:33 AM
Default Re: (FatJoe)
well i had the odassy engine in the car and gave it much power ...by the way its a 97 odassy engine ... 1 year later it blew a piston and i changed it to a 93 lx engine ....llost more power tho ... the car came with the 97 engine so i think they did it cause it moved more faster that the 91 engine....
what i need to know is a h22 better thana h23 ? witch is dohc ?? witch one is easy just to swap in ?
this is for my 2dr accord 1990 and i have 491,129 but still runs stong just want to change cause i think its about that time don't ya think ?
Old Sep 11, 2004 | 09:06 AM
FatJoe's Avatar
both are easy to swap in, both are dohc, h22 is dohc vtec, h23 is dohc non-vtec
get a JDM h22a, it has 200 HP and 161 TQ
an h23a(lets not get into the expensive h23a talk here please) only has about 160 hp and 157 or so TQ. the only part about the h22a that makes it harder to swap is adding 4 wires to be hooked up for vtec, which isnt hard at all. so get the h22a, unless you make no money and have none saved up, then you should just do no swap at all.
Old Sep 11, 2004 | 09:07 AM
TOAB's Avatar
youre going to have to start using the search feature.
h22 or dohc f22b would be the only 2 i consider. on you can get for an average of 2000 the other for like 700...
http://www.japanstarmotor.com
Old Sep 11, 2004 | 09:25 AM
FatJoe's Avatar
Default Re: (TOAB)
i wouldnt go to japanstarmotor... ive heard some horror stories of that place...
mudpuppy4life
Mar 21, 2013 04:52 PM
accord4style
Dec 11, 2004 05:50 AM
Doug Pollom
Jun 6, 2004 05:35 PM
kasper
Mar 5, 2003 12:06 PM
