axle trouble Wont lock in
Old Sep 7, 2004 | 03:00 PM
PeterBeast's Avatar
Default axle trouble Wont lock in
I have a 95 del sol and i recently put in a h22a with manual tranny. the only problem i have to far is the passenger axle wont lock in the tranny it pops out a little and leaks tranny fluid. i looked inside the tranny and tried another axle. what is the trick to this and should i be using tranny fluid or reg oil?
Old Sep 7, 2004 | 03:04 PM
BlendedEJ8's Avatar
Default Re: axle trouble Wont lock in (PeterBeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PeterBeast &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 del sol and i recently put in a h22a with manual tranny. the only problem i have to far is the passenger axle wont lock in the tranny it pops out a little and leaks tranny fluid. i looked inside the tranny and tried another axle. what is the trick to this and should i be using tranny fluid or reg oil?</TD></TR></TABLE>
make sure the axle you are using has the same #of splines as the tranny does. get it about in and just slowly spin the axle until the teeth of the splines catch and lock into place. about the tranny fluid... i personaly use the GM syncromesh stuff. cheap and good stuff.
Old Sep 7, 2004 | 03:16 PM
Mwsol's Avatar
Default Re: axle trouble Wont lock in (BlendedEJ)
Like Blended said make sure its the same number of splines.
Honda MtF worked better then just a regular 10w30 for me.
Old Sep 7, 2004 | 03:18 PM
BlendedEJ8's Avatar
Default Re: axle trouble Wont lock in (Mwsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mwsol &raquo;</TD></TR><TR><TD CLASS="quote">Like Blended said make sure its the same number of splines.
Honda MtF worked better then just a regular 10w30 for me.</TD></TR></TABLE>
tru dat. nothign better than oem, but its personal choice my friend
Old Sep 7, 2004 | 03:21 PM
1niceSi's Avatar
I experienced this same problem last week during my swap.
As stated above, first count to make sure the splines on the axle are the same number. Second, check the splines for any damage. In my case, a few were warped a bit (even one being off by a fraction will cause it not to go in). The solution to my problem was to fill down the warped splines. Once I did that, it went it like butter.
Its also suggested to changed the C clip at the end of the axle.
Old Sep 7, 2004 | 04:41 PM
sleepinonacreeper's Avatar
Default Re: axle trouble Wont lock in (1niceSi)
the splined section on a h22 axle is longer than civics and integras. the clip doesn't go in far enough to retain itself . put the h22 inner on your axle.
Old Sep 8, 2004 | 11:46 AM
PeterBeast's Avatar
hey thanks alot ill try that this weekend.
Old Sep 11, 2004 | 10:42 AM
PeterBeast's Avatar
ok so i took out the integra axle and got a prelude one, now b4 i took it apart i shoved it in the tranny and it is in there good but there is still a little space, its not flush with the tranny???? hmmm im stomped and if i get it in i can just buy a boot and attach the outer integra axle????
RGoose18
Jun 29, 2008 11:35 PM
*Boostwerks*
19
May 3, 2006 09:20 AM
bak lee
Dec 3, 2004 08:48 AM
EJ1 wilcox
Jun 21, 2004 10:46 AM
preluder
Jul 15, 2003 08:23 PM
