OEM tach being off?
Old Sep 7, 2004 | 12:27 PM
ELSpool's Avatar
Default OEM tach being off?
My tach is off by about 400 rpms at redline, if you put in an aftermarket tach like autometer etc, and wire the aftermarket tach to the blue signal wire, will the aftermarket tach now read dead on to the actual rpms?
Old Sep 7, 2004 | 12:31 PM
darkcvc's Avatar
Blue Sedan Crew
Default Re: OEM tach being off? (ELSpool)
the aftermarket tach will be right
stock tachs are innacurate and suck
Old Sep 7, 2004 | 12:36 PM
ELSpool's Avatar
thanks, I guess OEM dash just gets the signal from a poor source? I wonder if it's possible to re-wire the signal to a better soruce, ie. of the distributor.
Old Sep 7, 2004 | 12:37 PM
Doctor CorteZ's Avatar
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">I guess OEM dash just gets the signal from a poor source? I wonder if it's possible to re-wire the signal to a better soruce, ie. of the distributor.</TD></TR></TABLE>
the OEM tach is wired off the distributor.
and yes , the factory tach is slightly off , its fast by about 200 rpms in the upper range.
the peak hold function on a VAFC will tell you that.
Old Sep 7, 2004 | 12:47 PM
ELSpool's Avatar
The dyno told me it was off, and more than 200rpms. So why is it off if it's wired off the distributor?
Old Sep 7, 2004 | 12:56 PM
poor electronics I guess.
its a civic , it was designed to get groceries...
Old Sep 7, 2004 | 01:43 PM
jeffk182's Avatar
Default Re: (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">poor electronics I guess.
its a civic , it was designed to get groceries...</TD></TR></TABLE>
I love it
Old Sep 7, 2004 | 02:46 PM
ridiculous's Avatar
Default Re: (jeffk182)
maybe they did it on purpose so the people who are really late dont redline the motor on the way to get milk and cereal!!! haha
Old Sep 7, 2004 | 02:53 PM
JDMlyfestyle's Avatar
My Tach says 8500 but VAFC says 9300... not just off by a little i see
Old Sep 7, 2004 | 03:21 PM
Relic1's Avatar
Just like everything else, if you want accurate it is going to cost you.
The civic may be well engineered but costing less is always a factor.
Old Sep 7, 2004 | 03:24 PM
dantastic's Avatar
my tach reads 9000 at my 8500rpm rev limter. the gauge itself is inaccurate.
Old Sep 7, 2004 | 03:44 PM
hayabusa160's Avatar
Default Re: (dantastic)
same here lol its off about 400
Old Sep 7, 2004 | 04:34 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: (hayabusa160)
yea.. i dont remember if it was like this before the swap, but after i put my gsr engine in the tac now rests at 0 when i'm idling.. My tack is off by so much. it really sucks. Then I never know when i'm gonna hit the rev limiter at the track, so it messes up my runs sometimes.
too bad my mom threw away my gsr cluster wiring.. GRRRRRRRRRRRRRRRRR
Old Sep 7, 2004 | 04:42 PM
Deemeetree's Avatar
Electrician
I idle at 100 RPM if you want to know how accurate it is.
remoer
May 21, 2008 03:48 PM
ek-g6
Sep 23, 2007 05:34 AM
DriveSlowHomie
Dec 13, 2005 08:43 PM
lj17
13
Oct 17, 2004 05:40 PM
