wont rev problem found?!?!
i found out why my car is in limp mode or safe mode i took it to a local shop that does swaps had to pay them 65 $ an hour they traced it down to the crank angle sensor they said my stock engine harness crank angle is plug b10 & b12 and the pins are in there nice and tight but there are no pins from the locash jumper harness going into them to give those two wires a signal.
anyone know how to fix this i have the stock crx 1990 crx engine harness
and a p28 ecu where can or were do i run the sensor wires from there harness from the ecu or jumper harness into plugs b10 & b1
help would be great
http://www.we-todd-did-racing....k1NDE
[IMG][/IMG][IMG][/IMG]
help would be great
yes exactly i can take those wires from the dizzy and run them to b10 and b12 which they already are!
hence not getting a signal since no ecu signal to plug
but there is no wires coming from the ecu to the jumper into b10 and b12
i will have to hard wire the crank angle sensors from the p28 ecu to the b plug which locash should have done but they didnt i think they are sick of me now lol
but i dont know how or where to wire them from i know where to go with them though
bent
bent
Dcaustin156
Oct 28, 2013 04:03 PM
Driven
14
Sep 4, 2004 10:03 PM
