HELP!!! Power Surging problem??!?!??!?!
Old Sep 6, 2004 | 10:27 PM
CHONCH's Avatar
Default HELP!!! Power Surging problem??!?!??!?!
i dunno if anyone has experienced this before, but here goes:
when i hit my brakes or flip on my brights, all the lights in my car and my headlights get dim for a second.
i have an old battery, but there is no sign of it getting weak or anything, the lights aren't dim, and it turns the car on just fine. the lack of power also turns all of my accessories off and back on again (radar detector, etc, and yes, i have them all wired right, have had 0 problems with them before this).
if anyone has had this problem before and knows the remedy, please let a bro know, cuz this sucks!!!
Old Sep 6, 2004 | 10:40 PM
Archidictus's Avatar
Unceasing Measure
Default Re: HELP!!! Power Surging problem??!?!??!?! (twinturbobb)
Alternator, battery, bad grounds, huge vacuum leaks causing odd ECU readings, etc.
Old Sep 7, 2004 | 08:46 AM
CHONCH's Avatar
its not a bad ground, or vacuum leak. i think it might be the alternator or the battery.
i dont really think its the alternator though, cuz my system would be dimming my lights all the time if i had a bad alternator, and the lights never dim from music, just from me hitting my brakes....
Old Sep 7, 2004 | 08:55 AM
4dohs4mohoes's Avatar
Default Re: (twinturbobb)
Id say a vacume leak or loose ground somewhere.
Old Sep 7, 2004 | 10:36 AM
CHONCH's Avatar
how could a vacuum leak cause a sudden power problem like this?
Old Sep 7, 2004 | 11:19 AM
CHONCH's Avatar
bump
this is a tech forum, so how about some tech help!
Old Sep 7, 2004 | 05:22 PM
CHONCH's Avatar
wow.....
Old Sep 7, 2004 | 05:44 PM
2lua's Avatar
check your alternator! take the car to autozone, napa or advance auto to get your alternator check. they can test it in the car.
Old Sep 7, 2004 | 06:39 PM
CHONCH's Avatar
i already checked the alternator. it puts out a little over 14 volts while the car is at idle...
Old Sep 7, 2004 | 06:43 PM
2lua's Avatar
did you check it with full load on the alternator?
Old Sep 7, 2004 | 08:50 PM
CHONCH's Avatar
yeah, the output was still a little over 14 volts with the engine revving.....
its odd, the car did none of the **** tonight. the lights did not dim when i hit the brakes, nothing turne off and back on when i hit my high beams, very strange.
i think my poop is possessed.....
Old Sep 9, 2004 | 06:32 PM
CHONCH's Avatar
all the civics in the world, and no one has had this problem???
Old Sep 9, 2004 | 10:46 PM
BatuKing's Avatar
Do a load test on your battery to see if it supplying sufficent power when your car uses alot of AMPS for the lights.
I use a VAT 40 and some places can check the battery for you,
Now you said your alternator puts out 14 volts now turn on all the lights and see if it still does, and check for AC output on the alternator and on the battery.
vdawg559
Jan 4, 2008 06:39 PM
super china china
Dec 24, 2007 08:28 PM
duyfash0
Jul 1, 2007 05:22 PM
MzStreetracer
Mar 6, 2007 08:38 PM
d16lxciv
Mar 3, 2006 11:30 AM
