can you...
Old Sep 6, 2004 | 07:51 PM
Turbo Dan's Avatar
Default can you...
how hard is it to change the front tranny mount on a d series?
do you have to do anything else to remove it, or can you simple unbolt it and take it out?
Old Sep 6, 2004 | 08:06 PM
yellowcrx1991's Avatar
Default Re: can you... (Turbo Dan)
Removing it is easy, only three bolts. Bolting it back up, the only hard part is the tension that has to be put on the rubber in the mount in order to align it with the transmission bolt hole. I used a jack to hold up the transmission and relieve pressure on the mount then a screwdriver to align the rubber and lead the bolt.
Old Sep 6, 2004 | 08:13 PM
Turbo Dan's Avatar
Default Re: can you... (yellowcrx1991)
thanx
you are using the same turbo as i am
its a good unit for the price.
Old Sep 6, 2004 | 08:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Dan &raquo;</TD></TR><TR><TD CLASS="quote">thanx
its a good unit for the price.</TD></TR></TABLE>
Yeah, but I decided to check its axial play. Its has some pretty big play, I'm debating whether to use it(if I can) or search for another.
chickenwing
Sep 15, 2008 09:34 PM
fin781
Aug 23, 2007 02:15 PM
Mysterious
Mar 27, 2006 02:04 PM
DMF
Oct 12, 2003 09:30 PM
david90
Aug 15, 2003 03:24 PM
