idle problem please haelp
i got a 92 95 civic with a gsr swap . i just put a skunk 2 manifold in and after my idle is horrible . when i start my car it goes up to 2000 rpms then drops to 1200 and then starts to go up and down like theres a vacuum leak , but i smoked the engine to see if theres leaks but none where there . i dont know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">Check your throttle position sensor and your IAC. One or both of those is most likely your culprit.
It may not be..
Did it do this before you did the IM swap?
If not then it has something to do with the install/swap
Spray water around the IM gasket and see if it bubbles, if it does then you have a vac leak.
goodluck and let us know y0!
</TD></TR></TABLE>It may not be..
wakajdm8732
Dec 15, 2011 09:51 AM
builtsinglecam
Apr 27, 2009 06:10 PM
