B18C obd2 into EG obd1 .....????????
Old Sep 6, 2004 | 05:15 PM
EG*MonKEY's Avatar
Default B18C obd2 into EG obd1 .....????????
Hello i have a us spec obd2 b18c5 .....i want to swap it into my Civic which currently has a 95 OBD1 B18b......i do not have the obd2 engine harness....
. 1 ...i just have the b18c long block with dizzy and alternator.....no intake manifold...but i have a aftermarket one and throttle body
.....2 ...what can i do to use the obd2 dizzy....or use my obd1 dizzy off the LS
.....3...any other sugguestions???? thank you....
ive done a couple of swaps...just never obd2 into obd1 car.....thank you
Old Sep 6, 2004 | 05:17 PM
numbnuts22715's Avatar
Default Re: B18C obd2 into EG obd1 .....???????? (EG*MonKEY)
youll have to get an engine conversion harness thingy.. Hasport sells them.
Old Sep 6, 2004 | 05:33 PM
3.point.2's Avatar
im in the same position, putting an obd2 h23 in a 95 cx hatch. you should be able to use the obd2 dizzy if you have the obd2 engine harness. but since you dont i dont know if you can use the dizzy. you can modify an obd2 harness to work with an obd1 dizzy so i would imagine you can do it the other way around too. as for the conversion harness if youre talking about the jumper harness thats just like a foot long good luck finding the one you need. i cant find one that goes from obd1-obd2. only the other way around. if hasport has one let me know cause ive searched their site and couldnt find anything that would work for me.
anonymus913
May 1, 2009 09:45 AM
NOman0608
Jul 26, 2007 10:28 AM
wade
Jan 23, 2004 10:01 AM
