Engine builders: bearing clearance ???'s
Old Sep 6, 2004 | 04:54 PM
Phoenix1's Avatar
Default Engine builders: bearing clearance ???'s
I've got a GSR block with a balanced type r crank. With ACL bearings, the oil clearances are WAY too tight on the mains. I had gotten the bearings through a friend from Camp 1320, and my friend mentioned the tight clearance problem to Tom (from Camp) the other day. He said to sand the outside of the bearing with 1200 grit sandpaper to obtain the proper clearance. I've never heard of this, but Tom said many engine builders do this.
Input?
Thanks in advance.
Old Sep 6, 2004 | 06:35 PM
StyleTEG's Avatar
Default Re: Engine builders: bearing clearance ???'s (Autorotica)
What if you sand uneven?
get the right sized bearings.
Old Sep 6, 2004 | 08:54 PM
IN VTEC's Avatar
Have the machine shop polish the journals enough to take out a couple of ten-thou, or however much you need.
1990_integra_DA9
Aug 10, 2008 07:38 PM
Dyzee
10
Apr 28, 2004 11:56 AM
turbociv
15
Mar 11, 2004 01:16 PM
mattb16a1civic
Oct 13, 2003 07:52 PM
TheSwift1
Nov 12, 2002 08:12 AM
