y1 lsd locked up?
Old Sep 6, 2004 | 04:40 PM
EF'n's Avatar
Default y1 lsd locked up?
cable y1 lsd trans. seems the lsd is locked up? not really sure how they work. very hard to turn, acts like a welded diff.
tranny guro's: is there a way to get this to free up? or do i just need to **** can and get another? also the vss ring spins free on the diff. whats up with that? should spin with it, so the speedo no workie on this too.
Old Sep 8, 2004 | 04:53 PM
MinorObsession's Avatar
Default Re: y1 lsd locked up? (revhardracing)
anyone? help us please
Old Sep 8, 2004 | 06:26 PM
PyroProblem's Avatar
Default Re: y1 lsd locked up? (MinorObsession)
Im guessing the tranny is still in the car.The wheels should not be hard to turn at all.And since you said the VSS is not working either makes me think somethings definitely up with your tranny(ring gear).
If its hard to turn or making any wierd noises,It definitely needs to be opened up and repaired.
Hopefully it hasnt destroyed everything inside yet and you can repair it.
Good luck!
Old Sep 9, 2004 | 07:37 PM
Default Re: y1 lsd locked up? (PyroProblem)
tranny is out of car and taken appart, vss gear is no longer attached to diff. and lsd is locked, almost like it was welded. Does anyone know if this can be taken appart without special tools. the lsd that is?
91whiteREX
Jun 14, 2009 06:24 PM
xthekidx
Transmission & Drivetrain
Sep 16, 2008 06:15 PM
highmilehatch
Jul 18, 2007 06:35 AM
speedKILLS
Jul 24, 2006 05:52 PM
NightHawkC5
Feb 27, 2003 10:58 AM
