High Heat Flexible Hose For Exhaust Needed. What can I use????
Old Sep 6, 2004 | 04:05 PM
Full Race A6's Avatar
Default High Heat Flexible Hose For Exhaust Needed. What can I use????
I have a project with my brother going, using a 350 chevy engine but for the exhaust we need to be able to flex the exhaust 90 degrees at times.
We need a hose that about 1 foot in length, 2.25" diamter that can take the heat from the exhaust pipes getting hot, wed clamp them with a few muffler clamps
Can rad hose take the beating? Which hose can?
Something cheap and easily found I hope
Thanks
Old Sep 6, 2004 | 04:28 PM
Burke's Avatar
Banned
Default Re: High Heat Flexible Hose For Exhaust Needed. What can I use???? (Full Race A6)
try summitracing.com for 90 bends or use exhaust repair kit stuff. autozone etc carry up to 2.25 in kits
Old Sep 6, 2004 | 04:39 PM
Default Re: High Heat Flexible Hose For Exhaust Needed. What can I use???? (Burke)
its not a permanent 90 degree bend, I need it to be hose because the exhaust is going to be moving from side to side constintely
Also, rad hose to me seems like it would work, flexible and takes high heat all day long
but could it stand up to exhaust heat and being strapped onto hot metal
Old Sep 6, 2004 | 07:03 PM
v4lu3s's Avatar
RTFM
raediator hose will melt.
its not designed to handle that high a heat....
Old Sep 6, 2004 | 07:05 PM
.dave's Avatar
i HAS questions ?
Default Re: (v4lu3s)
What about a 90 degree bend and a piece of flex bellows?
Also, check out McMaster-Carr. Unfortunately, I can't link directly into the catalog but pages 178 and 179 have some flexible stainless tubing good for up to 1000 degrees.
Old Sep 6, 2004 | 07:17 PM
Default Re: (dave.g)
Need it pretty quick
And also why would rad hose melt? It takes boiling hot coolant all day long
Even if I wrap gasket meterial around the 2 ends of the pipe first then clamp the rad hose onto that? leaving about 4 inch gap where there is no metal
Mind you this bend is about 6 feet after the actual headers and gutted cat and a resonator
Old Sep 6, 2004 | 07:23 PM
.dave's Avatar
i HAS questions ?
Default Re: (Full Race A6)
Why exactly is it going to be moving side to side constantly?
Old Sep 6, 2004 | 07:31 PM
when its aimed at a target.....
Old Sep 6, 2004 | 07:42 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full Race A6 &raquo;</TD></TR><TR><TD CLASS="quote">when its aimed at a target.....</TD></TR></TABLE>
WTF!?! What is there a flame thrower in there too?
Old Sep 7, 2004 | 04:44 AM
Burke's Avatar
Banned
coolant = 250 F
exhaust = 500 - 1000 F
those kind of temps will melt rubber in a matter of seconds
get that flexible exhaust repair kit, it will work perfectly
Old Sep 7, 2004 | 07:51 AM
Default Re: (Burke)
The exhaust coming right out of the motor is that temperature. At the tailpipe its less than 80 degrees.... Im trying it
Old Sep 7, 2004 | 08:27 AM
v4lu3s's Avatar
RTFM
its not just the exhasut gas temp that has to be considered, its the temperature of the metal as well, i guarantee if you put a piece of rubber coolant hose up against a piece of your exhaust anywhere near the header, or the catalyst it will melt quickly.
Old Sep 7, 2004 | 08:28 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full Race A6 &raquo;</TD></TR><TR><TD CLASS="quote">The exhaust coming right out of the motor is that temperature. At the tailpipe its less than 80 degrees.... Im trying it</TD></TR></TABLE>
a rubber hose is going to melt. 80 deg. at the tip? have a buddy rev the car and put your hand at the exhaust tip... 80 deg my ***
CRX Si69
Welding / Fabrication
Apr 17, 2012 03:08 AM
Nisif
Aug 12, 2006 04:53 PM
Nisif
Aug 11, 2006 07:02 PM
FourthGenHatch
Jan 31, 2003 12:42 PM
Greyout
Apr 4, 2002 12:58 PM
